Saltar al contenido principal
Steelseries Rival 700 Gaming Mouse Nameplate Replacement
Qué necesitas
  1. Steelseries Rival 700 Gaming Mouse Nameplate Replacement, Disconnect the mouse from your computer: paso 1, imagen 1 de 2 Steelseries Rival 700 Gaming Mouse Nameplate Replacement, Disconnect the mouse from your computer: paso 1, imagen 2 de 2
    • To avoid electronically damaging either your computer or your mouse, unplug the usb cable from its socket.
  2. Steelseries Rival 700 Gaming Mouse Nameplate Replacement, Disconnect the cable from the mouse: paso 2, imagen 1 de 3 Steelseries Rival 700 Gaming Mouse Nameplate Replacement, Disconnect the cable from the mouse: paso 2, imagen 2 de 3 Steelseries Rival 700 Gaming Mouse Nameplate Replacement, Disconnect the cable from the mouse: paso 2, imagen 3 de 3
    • The Rival 700 mouse is a non wireless mouse. The micro-USB cable end is an elbow socket, secured by a plastic clip.
    • To disconnect the cable from the mouse, firmly press the plastic clip using your thumb
  3. Steelseries Rival 700 Gaming Mouse Nameplate Replacement, Nameplate removal: paso 3, imagen 1 de 2 Steelseries Rival 700 Gaming Mouse Nameplate Replacement, Nameplate removal: paso 3, imagen 2 de 2
    • The original nameplate is a soft rubber one that can be removed just by pulling it softly out of its socket.
    • WARNING: When reassembling, if you're using a custom nameplate that may not be as stretchable as the original one, insert it softly, and use a lime tool on the new part to avoid damaging the mouse socket.
  4. Steelseries Rival 700 Gaming Mouse Nameplate Replacement, Nameplate printing: paso 4, imagen 1 de 1
    • You will be able to download the 3D files to design a custom nameplate on the Steelseries website. The link is also provided in the part description.
    • On this picture, the original "RIVAL" nameplate will be replaced with a new one on which i just had my Twitch ID printed.
    • Be creative, use colored plastic, put logos and drawings on your mouse.
Conclusión
Una persona más ha completado esta guía.
Vincent Monteil
Miembro Desde 07/06/13
6,975 Reputación
19 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 2,249
