Saltar al contenido principal
Steelseries Rival 700 Gaming Mouse Disassembly
Qué necesitas
  1. Steelseries Rival 700 Gaming Mouse Disassembly, Disconnect the mouse from your computer: paso 1, imagen 1 de 2 Steelseries Rival 700 Gaming Mouse Disassembly, Disconnect the mouse from your computer: paso 1, imagen 2 de 2
    • To avoid electronically damaging either your computer or your mouse, unplug the usb cable from its socket.
  2. Steelseries Rival 700 Gaming Mouse Disassembly, Disconnect the cable from the mouse: paso 2, imagen 1 de 3 Steelseries Rival 700 Gaming Mouse Disassembly, Disconnect the cable from the mouse: paso 2, imagen 2 de 3 Steelseries Rival 700 Gaming Mouse Disassembly, Disconnect the cable from the mouse: paso 2, imagen 3 de 3
    • The Rival 700 mouse is a non wireless mouse. The micro-USB cable end is an elbow socket, secured by a plastic clip.
    • To disconnect the cable from the mouse, firmly press the plastic clip using your thumb
  3. Steelseries Rival 700 Gaming Mouse Disassembly, Nameplate removal: paso 3, imagen 1 de 2 Steelseries Rival 700 Gaming Mouse Disassembly, Nameplate removal: paso 3, imagen 2 de 2
    • The original nameplate is a soft rubber one that can be removed just by pulling it softly out of its socket.
    • WARNING: When reassembling, if you're using a custom nameplate that may not be as stretchable as the original one, insert it softly, and use a lime tool on the new part to avoid damaging the mouse socket.
  4. Steelseries Rival 700 Gaming Mouse Disassembly, Nameplate printing: paso 4, imagen 1 de 1
    • You will be able to download the 3D files to design a custom nameplate on the Steelseries website. The link is also provided in the part description.
    • On this picture, the original "RIVAL" nameplate will be replaced with a new one on which i just had my Twitch ID printed.
    • Be creative, use colored plastic, put logos and drawings on your mouse.
  5. Steelseries Rival 700 Gaming Mouse Disassembly, Top cover removal: paso 5, imagen 1 de 3 Steelseries Rival 700 Gaming Mouse Disassembly, Top cover removal: paso 5, imagen 2 de 3 Steelseries Rival 700 Gaming Mouse Disassembly, Top cover removal: paso 5, imagen 3 de 3
    • Use both your index and thumb to gently pry the top cover out from the mouse.
    • This part is a thin plastic one which needs a certain amount of strength to be removed. Be careful not to break it.
  6. Steelseries Rival 700 Gaming Mouse Disassembly, Top cover replacement: paso 6, imagen 1 de 1
    • Steelseries sells a set of two different covers to replace the original one, with a sweat-resistant one f.e.
    • Check the parts section for the purchase link.
    • On the left, you can see on the wide led slot that is used to color the Steelseries logo on your mouse.
  7. Steelseries Rival 700 Gaming Mouse Disassembly, Sensor screws: paso 7, imagen 1 de 2 Steelseries Rival 700 Gaming Mouse Disassembly, Sensor screws: paso 7, imagen 2 de 2
    • Use a Philips #0 screwdriver to remove the four screws that are keeping the mouse sensor assembly sealed.
  8. Steelseries Rival 700 Gaming Mouse Disassembly, Sensor removal: paso 8, imagen 1 de 1
    • Insert your thumb and index in the two mouse holes and gently pry the sensor assembly out from its socket.
  9. Steelseries Rival 700 Gaming Mouse Disassembly, Sensor socket: paso 9, imagen 1 de 1
    • The sensor assembly is linked to the mouse body with a 10-pin Steelseries custom connector.
  10. Steelseries Rival 700 Gaming Mouse Disassembly: paso 10, imagen 1 de 1
    • Only four screws have to be removed to entirely re-design this gaming mouse, which is not that expensive regarding the high performance, features, and customizability.
Conclusión
7 personas más completaron esta guía.
Vincent Monteil
Miembro Desde 07/06/13
6,975 Reputación
19 Guías creadas
12 comentarios
Is it possible to open it up so that you can see the mouse wheel? Mine needs some lubrication since it's making a squeaking sound as soon as I use the mouse wheel. Level of annoyance is over 9000!
andned - Contestar
Hi @andned,
Never gave it a try as long as mine doesn't need it. It is a pretty expensive mouse so I wouldn't like to damage it.
The purpose of this guide was to demonstrate how easy customizing the mouse is easy.
Give us your feedback if you managed to do it :)
Vincent Monteil -
I to have had squeeky mouse wheel sound with BOTH of my Steelseries 700 Rival. Its so annoying, otherwise a very solid mouse. Would love to find a way to open it more up without damaging it.
Richard - Contestar
You didn’t disassemble anything.
Albert Einstein - Contestar
I actually did :) my purpose was to demonstrate how easy it was to customise the mouse.
I think that you meant “this isn’t deep repair”. Indeed, it isn’t :)
Vincent Monteil -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 21
Ultimos 30 días: 71
Todo El Tiempo: 18,009
