Saltar al contenido principal
SteelSeries Nimbus+ Triggers Replacement
Qué necesitas
  1. SteelSeries Nimbus+ Triggers Replacement, Remove the phone mount: paso 1, imagen 1 de 2 SteelSeries Nimbus+ Triggers Replacement, Remove the phone mount: paso 1, imagen 2 de 2
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
  2. SteelSeries Nimbus+ Triggers Replacement, Remove the sticker: paso 2, imagen 1 de 1
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
  3. SteelSeries Nimbus+ Triggers Replacement, Unscrew the back cover: paso 3, imagen 1 de 1
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
  4. SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: paso 4, imagen 1 de 2 SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: paso 4, imagen 2 de 2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
  5. SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: paso 5, imagen 1 de 2 SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: paso 5, imagen 2 de 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
  6. SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: paso 6, imagen 1 de 2 SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: paso 6, imagen 2 de 2
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
  7. SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: paso 7, imagen 1 de 2 SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: paso 7, imagen 2 de 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
  8. SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: paso 8, imagen 1 de 3 SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: paso 8, imagen 2 de 3 SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: paso 8, imagen 3 de 3
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
  9. SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: paso 9, imagen 1 de 3 SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: paso 9, imagen 2 de 3 SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: paso 9, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
  10. SteelSeries Nimbus+ Triggers Replacement, Remove the back cover assembly: paso 10, imagen 1 de 1
    • Remove the back cover assembly.
  11. SteelSeries Nimbus+ Triggers Replacement, Unscrew the board: paso 11, imagen 1 de 1
    • Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
  12. SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: paso 12, imagen 1 de 3 SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: paso 12, imagen 2 de 3 SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: paso 12, imagen 3 de 3
    • Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
  13. SteelSeries Nimbus+ Triggers Replacement, Remove the board: paso 13, imagen 1 de 1
    • Remove the board with the thumbsticks from the mainboard.
  14. SteelSeries Nimbus+ Triggers Replacement, Unscrew the mainboard: paso 14, imagen 1 de 1
    • Use a Phillips screwdriver to remove the five 7.0 mm-long screws securing the mainboard to the front assembly.
  15. SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: paso 15, imagen 1 de 3 SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: paso 15, imagen 2 de 3 SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: paso 15, imagen 3 de 3
    • Use your fingers to lift up the mainboard from the front case.
    • Remove the mainboard.
  16. SteelSeries Nimbus+ Triggers Replacement, Unscrew the triggers: paso 16, imagen 1 de 1
    • Use a Phillips screwdriver to remove the four 7.0 mm screws securing the triggers on the motherboard.
  17. SteelSeries Nimbus+ Triggers Replacement, Release the right trigger: paso 17, imagen 1 de 2 SteelSeries Nimbus+ Triggers Replacement, Release the right trigger: paso 17, imagen 2 de 2
    • Pull the right trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
  18. SteelSeries Nimbus+ Triggers Replacement, Release the left trigger: paso 18, imagen 1 de 2 SteelSeries Nimbus+ Triggers Replacement, Release the left trigger: paso 18, imagen 2 de 2
    • Pull the left trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
Conclusión
Adriana Zwink
Miembro Desde 12/18/19
61,796 Reputación
167 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 123
23,623 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 422
