Saltar al contenido principal
SteelSeries Arctis Pro Microphone Cable Replacement
Qué necesitas
  1. SteelSeries Arctis Pro Microphone Cable Replacement, Microphone Cable: paso 1, imagen 1 de 2 SteelSeries Arctis Pro Microphone Cable Replacement, Microphone Cable: paso 1, imagen 2 de 2
    • Remove ear cushion by pulling the cushion up and towards yourself.
    • Repeat this motion around the cushion until it comes free.
  2. SteelSeries Arctis Pro Microphone Cable Replacement: paso 2, imagen 1 de 2 SteelSeries Arctis Pro Microphone Cable Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the 3 case screws.
    • Lift the driver assembly away from the rest of the housing.
  3. SteelSeries Arctis Pro Microphone Cable Replacement: paso 3, imagen 1 de 3 SteelSeries Arctis Pro Microphone Cable Replacement: paso 3, imagen 2 de 3 SteelSeries Arctis Pro Microphone Cable Replacement: paso 3, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the three 5 mm screws.
    • Push the headset volume dial in-words towards the housing while simultaneously pulling the board towards yourself.
  4. SteelSeries Arctis Pro Microphone Cable Replacement: paso 4, imagen 1 de 1
    • De-solder the six connections on the side of the main board.
  5. SteelSeries Arctis Pro Microphone Cable Replacement: paso 5, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the two 5 mm screws that secure the microphone holder.
  6. SteelSeries Arctis Pro Microphone Cable Replacement: paso 6, imagen 1 de 3 SteelSeries Arctis Pro Microphone Cable Replacement: paso 6, imagen 2 de 3 SteelSeries Arctis Pro Microphone Cable Replacement: paso 6, imagen 3 de 3
    • Pull the microphone assembly and cable out of the housing and out towards you until it comes free.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 68
Todo El Tiempo: 1,148
