Introducción
If the volume scroll wheel is not adjusting the volume or rotating as it should be, follow this guide to replace the wheel.
Caution: Ensure hands are dry. Moisture could mess up the wiring. Be gentle and remove necessary pieces carefully to not break the device.
Qué necesitas
Remove the ear cushion on the left ear muff
This is done by pulling slightly on the outside of the cushion and moving around it until it comes off
Un comentario
thanks for the tutorial
I have the equipment and skills to do this repair, but need to source parts.
Where would I get a replacement wheel and what would be the part #?
My wheel is starting to fail and as I adjust it, one earpiece cuts in and out. There is also a scratching/static sound as I turn the wheel
