Saltar al contenido principal
SteelSeries Arctis Pro Headset Mute Button Cap Replacement
Qué necesitas
  1. SteelSeries Arctis Pro Headset Mute Button Cap Replacement, Headset Mute Button Cap: paso 1, imagen 1 de 2 SteelSeries Arctis Pro Headset Mute Button Cap Replacement, Headset Mute Button Cap: paso 1, imagen 2 de 2
    • Remove the ear cushion by pulling the edge up and towards yourself
    • Repeat this motion all the way around the ear cushion until it comes free
  2. SteelSeries Arctis Pro Headset Mute Button Cap Replacement: paso 2, imagen 1 de 2 SteelSeries Arctis Pro Headset Mute Button Cap Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the 3 case screws.
    • Remove the driver assembly from the rest of the housing
  3. SteelSeries Arctis Pro Headset Mute Button Cap Replacement: paso 3, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the three 5 mm screws.
  4. SteelSeries Arctis Pro Headset Mute Button Cap Replacement: paso 4, imagen 1 de 2 SteelSeries Arctis Pro Headset Mute Button Cap Replacement: paso 4, imagen 2 de 2
    • Remove the circuit board by pushing the scroll wheel out of the board and pulling it from the other side.
  5. SteelSeries Arctis Pro Headset Mute Button Cap Replacement: paso 5, imagen 1 de 2 SteelSeries Arctis Pro Headset Mute Button Cap Replacement: paso 5, imagen 2 de 2
    • Grab the keycap and pull outwards till it comes free
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 54
Todo El Tiempo: 965
