Saltar al contenido principal
SteelSeries Apex 64145 USB Port Connector Replacement
Qué necesitas
  1. SteelSeries Apex 64145 USB Port Connector Replacement, Gel Membrane: paso 1, imagen 1 de 1
    • Unplug the keyboard from the computer.
  2. SteelSeries Apex 64145 USB Port Connector Replacement: paso 2, imagen 1 de 1
    • Unscrew the twenty black 4.5 mm Phillips #1 screws on the back of the keyboard.
  3. SteelSeries Apex 64145 USB Port Connector Replacement: paso 3, imagen 1 de 1
    • Pry open the back of the keyboard.
  4. SteelSeries Apex 64145 USB Port Connector Replacement: paso 4, imagen 1 de 2 SteelSeries Apex 64145 USB Port Connector Replacement: paso 4, imagen 2 de 2
    • Remove the gel membrane.
  5. SteelSeries Apex 64145 USB Port Connector Replacement, LED: paso 5, imagen 1 de 2 SteelSeries Apex 64145 USB Port Connector Replacement, LED: paso 5, imagen 2 de 2
    • Unscrew the two silver 4.0 mm Phillips #1 screws and the three black 6.5 mm Phillips #1 screws holding the silicone sheets.
  6. SteelSeries Apex 64145 USB Port Connector Replacement: paso 6, imagen 1 de 1
    • Flip the chip slightly in order to remove the sheets.
  7. SteelSeries Apex 64145 USB Port Connector Replacement: paso 7, imagen 1 de 1
    • Remove the sheets.
  8. SteelSeries Apex 64145 USB Port Connector Replacement: paso 8, imagen 1 de 2 SteelSeries Apex 64145 USB Port Connector Replacement: paso 8, imagen 2 de 2
    • Unscrew the two silver 4.5 mm Phillips #1 screws and the seven 5.0 mm Phillips #1 screws that deter the plastic panel from removal.
  9. SteelSeries Apex 64145 USB Port Connector Replacement: paso 9, imagen 1 de 1
    • Remove the plastic panel and the white sheet.
  10. SteelSeries Apex 64145 USB Port Connector Replacement: paso 10, imagen 1 de 3 SteelSeries Apex 64145 USB Port Connector Replacement: paso 10, imagen 2 de 3 SteelSeries Apex 64145 USB Port Connector Replacement: paso 10, imagen 3 de 3
    • Unplug the wires connected to the LEDs.
  11. SteelSeries Apex 64145 USB Port Connector Replacement: paso 11, imagen 1 de 2 SteelSeries Apex 64145 USB Port Connector Replacement: paso 11, imagen 2 de 2
    • Remove the LEDs.
  12. SteelSeries Apex 64145 USB Port Connector Replacement, USB Port Connector: paso 12, imagen 1 de 1
    • Unscrew the two 4.5 mm silver Phillips #1 screws that hold the USB port connector.
  13. SteelSeries Apex 64145 USB Port Connector Replacement: paso 13, imagen 1 de 1
    • Unplug the wires and remove the USB port connector.
Conclusión
2 personas más completaron esta guía.
Zwe Phone Shein
Miembro Desde 02/28/17
559 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G1, Nance Spring 2017 Miembro de USF Tampa, Team S1-G1, Nance Spring 2017
USFT-NANCE-S17S1G1
4 Miembros
10 Guías creadas
2 comentarios
the 2 usb in the keyboard what amp are they running on.. 500mA ? I hope for 1500-2000 mA
And what standard are they ? USB3 ??
Simon Sundström - Contestar
can the other part be replaced too. like the power board ?
i think i have a powerboard problem and if I can replace it that would be awesome, as I love my keyboard and im
very very attached to it. I was playing a video game, nothing too harsh , and the lights went out and poof it never came back. never had a problem with this keyboard until 2 and a 1/2 years later that it did this. Its in a non-smoking room and gaming studio always kept very clean.
I would love to fix it to bring it back to life.
Twsted - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 15
Ultimos 30 días: 53
Todo El Tiempo: 3,032
