Saltar al contenido principal
Starbucks Barista Ready Light Replacement
Qué necesitas
  1. Starbucks Barista Ready Light Replacement, Ready Light: paso 1, imagen 1 de 2 Starbucks Barista Ready Light Replacement, Ready Light: paso 1, imagen 2 de 2
    • Unscrew the 6 screws from the back panel.
    • Remove the back panel.
  2. Starbucks Barista Ready Light Replacement: paso 2, imagen 1 de 3 Starbucks Barista Ready Light Replacement: paso 2, imagen 2 de 3 Starbucks Barista Ready Light Replacement: paso 2, imagen 3 de 3
    • Locate the ready light.
    • Gently push the fixture against the Barista wall.
    • Pull the fixture straight up to release it.
    • Note: The fixture works as a spring.
    • Note: The green cover from the front panel will "pop" off. Do not lose the green cover.
    • Disconnect the wire lead connectors.
    • Remove the ready light unit (fixture).
  3. Starbucks Barista Ready Light Replacement: paso 3, imagen 1 de 1
    • Replace the old LED with a new LED.
    • To put back, match the green cover to the slot of the LED fixture, then slide the fixture down against the barista wall.
Conclusión
Una persona más ha completado esta guía.
David
Miembro Desde 01/28/11
748 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 4-42, Regan Winter 2011 Miembro de Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 Miembros
5 Guías creadas
4 comentarios
Youth and sports for
Rich Ridout - Contestar
Where can I get a new LED bulb?
Paula - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 6,131
