Saltar al contenido principal
Starbucks Barista Pump Replacement
Qué necesitas
  1. Starbucks Barista Pump Replacement, Pump: paso 1, imagen 1 de 3 Starbucks Barista Pump Replacement, Pump: paso 1, imagen 2 de 3 Starbucks Barista Pump Replacement, Pump: paso 1, imagen 3 de 3
    • First remove all six screws on the back panel.
    • Remove the back panel, then set it aside.
    • Remove the two screws holding the bottom panel in place.
    • Remove the bottom panel, then set it aside.
  2. Starbucks Barista Pump Replacement: paso 2, imagen 1 de 3 Starbucks Barista Pump Replacement: paso 2, imagen 2 de 3 Starbucks Barista Pump Replacement: paso 2, imagen 3 de 3
    • Pull the drip tray out, then set it aside.
    • Turn the brew unit clockwise to unscrew.
    • Pull the tube that goes into water reservoir out.
    • Slide the water reservoir out through the front of the barista to remove it.
    • Remove the top tray from the backside.
  3. Starbucks Barista Pump Replacement: paso 3, imagen 1 de 3 Starbucks Barista Pump Replacement: paso 3, imagen 2 de 3 Starbucks Barista Pump Replacement: paso 3, imagen 3 de 3
    • Use an adjustable wrench to unscrew the connection tube between the pump and the boiler.
    • Pull off both tubes connecting on each side of the pump.
    • Remove the 3 electrical connectors from the pump.
  4. Starbucks Barista Pump Replacement: paso 4, imagen 1 de 3 Starbucks Barista Pump Replacement: paso 4, imagen 2 de 3 Starbucks Barista Pump Replacement: paso 4, imagen 3 de 3
    • Unscrew the two mounting bolts.
    • Remove the pump unit from the Barista.
    • Pull off the yellow end of the pump and unscrew T-shaped end.
    • See the links section of the device page for where to purchase a new pump.
Conclusión
16 personas más completaron esta guía.
Alex
Miembro Desde 01/28/11
503 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 4-42, Regan Winter 2011 Miembro de Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 Miembros
5 Guías creadas
22 comentarios
What is meant by "See the links section of the device page for where to purchase a new pump"? Which device page on which website? Are you not able to just post the link? Which type/model of pump is required?
nick - Contestar
My son and I successfully replaced the pump, but it didn't go quite as easily as I'd thought. We could not get the hose that connects the boiler to the pump off. Thankfully, my clever son realized we could turn the portion of the pump that screws into the t-end to get the old pump off and new one on.....tricky, but doable. The new pump is a bit noisier than the last, but she pulls beautiful shots. Thanks so much for this guide!
Bananaslug - Contestar
I put in a new pump and it still doesn’t work. I hear it him but can’t get it to pull water. I’ve tried the water in the line thing. How is the best way to prime it? Maybe that’s it?
wendy.tracy007 -
Wendy
Open the steam valve, so there is no back pressure inside the boiler preventing the pump from pulling water.
Gary Naka -
Thanks for this tip.
I had the same problem, could not get the tefflon tube out of the brass T/OPV.
Rotated the pump off the T/OPV.
Gary Naka -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 64
Todo El Tiempo: 36,701
