Saltar al contenido principal
Introducción
If your pencils are not properly sharpening, the problem could be a dull or worn cutter. This guide will show you how to replace the cutter component of your Staples 34462 Electric Pencil Sharpener.
Partes
No se especificaron partes.
  1. Pull out the shavings tray from the pencil sharpener.
    • Pull out the shavings tray from the pencil sharpener.
    • Beware of loose pencil shavings falling on your workspace.
  2. Turn the pencil sharpener on its side.
    • Turn the pencil sharpener on its side.
  3. Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
    • Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
    • Using the plastic opening tool, remove the back plastic feet.
    • After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
    • The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
  4. Carefully pull apart the bottom panel from the top panel.
    • Carefully pull apart the bottom panel from the top panel.
    • Be careful not to pull too forcefully as the panels are connected by wires.
    • Beware of pencil shavings falling out onto your workspace.
  5. Kits de Reparación de Android
    A new screen or battery is one kit away.
    Comprar Ahora
    Comprar Ahora
  6. Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
    • Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
  7. Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
    • Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
  8. Carefully pull the cover from the top panel and set it aside.
    • Carefully pull the cover from the top panel and set it aside.
  9. Orient the top panel so that the sensor bracket is facing you.
    • Orient the top panel so that the sensor bracket is facing you.
    • Using a Phillips00 screwdriver, remove four 10.42mm screws.
    • Using a Phillips00 screwdriver, remove two 6.96mm screws.
  10. Pull out the outside cover to remove it from the cutter chamber and set them side by side.
    • Pull out the outside cover to remove it from the cutter chamber and set them side by side.
  11. Carefully pull the cutter out of the cutter chamber.
    • Carefully pull the cutter out of the cutter chamber.
    • Beware of pencil shavings and debris.
Conclusión
Very clear, easy to follow. Nice photos.
uccbill - Contestar
where can I get a replacement cutter?
Mel Buchanan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 10
Últimos 30 Días: 18
Todo El Tiempo: 1,245
