Saltar al contenido principal
Stanley ST-222A-120 Pressure Sensor Replacement
  1. Stanley ST-222A-120 Pressure Sensor Replacement, Pressure Sensor: paso 1, imagen 1 de 1
    • Unplug the heater for safety during your repair.
  2. Stanley ST-222A-120 Pressure Sensor Replacement: paso 2, imagen 1 de 3 Stanley ST-222A-120 Pressure Sensor Replacement: paso 2, imagen 2 de 3 Stanley ST-222A-120 Pressure Sensor Replacement: paso 2, imagen 3 de 3
    • With your hands gently remove the plastic covers on either side of the heater.
  3. Stanley ST-222A-120 Pressure Sensor Replacement: paso 3, imagen 1 de 2 Stanley ST-222A-120 Pressure Sensor Replacement: paso 3, imagen 2 de 2
    • Use your hands to pry apart the plastic halves of the heater to see the internals of the device.
  4. Stanley ST-222A-120 Pressure Sensor Replacement: paso 4, imagen 1 de 2 Stanley ST-222A-120 Pressure Sensor Replacement: paso 4, imagen 2 de 2
    • Locate small pressure sensor replacement and small pressure pin at the bottom of the device.
  5. Stanley ST-222A-120 Pressure Sensor Replacement: paso 5, imagen 1 de 2 Stanley ST-222A-120 Pressure Sensor Replacement: paso 5, imagen 2 de 2
    • Use your hands to help guide the pressure pin back into a position where the replacement plate can slide back onto it.
    • Needle nose pliers may be a good assistant in this situation.
  6. Stanley ST-222A-120 Pressure Sensor Replacement: paso 6, imagen 1 de 2 Stanley ST-222A-120 Pressure Sensor Replacement: paso 6, imagen 2 de 2
    • While the plastic is open hold the pin out with a finger.
    • Line up the pressure plate to the pressure pin.
  7. Stanley ST-222A-120 Pressure Sensor Replacement: paso 7, imagen 1 de 2 Stanley ST-222A-120 Pressure Sensor Replacement: paso 7, imagen 2 de 2
    • Gently put the pressure plate back onto the pressure pin.
  8. Stanley ST-222A-120 Pressure Sensor Replacement: paso 8, imagen 1 de 3 Stanley ST-222A-120 Pressure Sensor Replacement: paso 8, imagen 2 de 3 Stanley ST-222A-120 Pressure Sensor Replacement: paso 8, imagen 3 de 3
    • Carefully press the plastic back together.
    • Be conscious not to interrupt the placement of the newly repaired pressure plate.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 20
Todo El Tiempo: 516
