Saltar al contenido principal
Stagg Electro-Acoustic Guitar Strings Replacement
Qué necesitas
  1. Stagg Electro-Acoustic Guitar Strings Replacement, Guitar Strings: paso 1, imagen 1 de 1
    • Place the string winder on the tuning key.
  2. Stagg Electro-Acoustic Guitar Strings Replacement: paso 2, imagen 1 de 1
    • Wind up the string winder counter-clockwise to loosen the strings.
  3. Stagg Electro-Acoustic Guitar Strings Replacement: paso 3, imagen 1 de 1
    • With the string clipper, clip the string under the neck of the guitar.
  4. Stagg Electro-Acoustic Guitar Strings Replacement: paso 4, imagen 1 de 1
    • Unwind the string from the machine head and remove it.
  5. Stagg Electro-Acoustic Guitar Strings Replacement: paso 5, imagen 1 de 1
    • With the string winder pop the string peg out of its hole.
  6. Stagg Electro-Acoustic Guitar Strings Replacement: paso 6, imagen 1 de 1
    • Place the colored circle end of the string in the peg hole.
  7. Stagg Electro-Acoustic Guitar Strings Replacement: paso 7, imagen 1 de 1
    • Put the peg in the hole with the string.
    • Pull the string while pushing the pin in.
  8. Stagg Electro-Acoustic Guitar Strings Replacement: paso 8, imagen 1 de 1
    • Precut the other side of the string by one and a half machine heads.
  9. Stagg Electro-Acoustic Guitar Strings Replacement: paso 9, imagen 1 de 1
    • Thread the string through the peg.
    • Wind the string clockwise from top to bottom with the string winder.
    • Do not overlap the string when winding it.
Conclusión
Repeat steps for each string.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 405
