Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
If the user has already visited the troubleshooting page and has determine the issue incurred is due to a faulty micro SD card reader,and cleaning the reader has not worked, then this will be the guide to use.
  1. Remove the six silver 11.4 mm Phillips #0 screws Pry open the device using a plastic opening tool if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
    • Remove the six silver 11.4 mm Phillips #0 screws
    • Pry open the device using a plastic opening tool if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
  2. Now that your device is open, remove the Styrofoam pad that covers the main circuit board. The adhesive should allow you to remove and replace it with ease.
    • Now that your device is open, remove the Styrofoam pad that covers the main circuit board. The adhesive should allow you to remove and replace it with ease.
    • Do this carefully to avoid tearing the pad.
  3. Remove the eight black 7.2 mm Phillips #0 screws from the top of the circuit board and remove the circuit board. Remove the eight black 7.2 mm Phillips #0 screws from the top of the circuit board and remove the circuit board. Remove the eight black 7.2 mm Phillips #0 screws from the top of the circuit board and remove the circuit board.
    • Remove the eight black 7.2 mm Phillips #0 screws from the top of the circuit board and remove the circuit board.
  4. Unscrew the one 7.2 mm Phillips #0 screw from the plastic piece covering the microSD reader. Then, unscrew the two 7.2 mm Phillips #0 screws from the  microSD reader and remove it from its fastening. Then, unscrew the two 7.2 mm Phillips #0 screws from the  microSD reader and remove it from its fastening.
    • Unscrew the one 7.2 mm Phillips #0 screw from the plastic piece covering the microSD reader.
    • Then, unscrew the two 7.2 mm Phillips #0 screws from the microSD reader and remove it from its fastening.
  5. On the back side of the reader there are nine wires. Un-solder these wires, remove the micro SD card reader, and solder on the replacement.
    • On the back side of the reader there are nine wires. Un-solder these wires, remove the micro SD card reader, and solder on the replacement.
    • Need Help Soldering? Check out Cómo soldar y desoldar conexiones for tips.
Conclusión
Andrew Gittens
Miembro Desde 22/09/14
140 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 4-5, Brown Fall 2014 Miembro de USF Tampa, Team 4-5, Brown Fall 2014
USFT-BROWN-F14S4G5
3 Miembros
6 Guías creadas
Where do you get the replacement parts?
clsutliff - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 362
