Saltar al contenido principal
Sprout Channel Cubby Speaker Replacement
Qué necesitas
  1. Sprout Channel Cubby Speaker Replacement, Dissasemble the device: paso 1, imagen 1 de 2 Sprout Channel Cubby Speaker Replacement, Dissasemble the device: paso 1, imagen 2 de 2
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
  2. Sprout Channel Cubby Speaker Replacement, Speaker: paso 2, imagen 1 de 2 Sprout Channel Cubby Speaker Replacement, Speaker: paso 2, imagen 2 de 2
    • While using the spatula, slowly get under the top part of the speaker. Then slowly move down the speaker to detach it from the device (there is a small amount of adhesive).
  3. Sprout Channel Cubby Speaker Replacement: paso 3, imagen 1 de 2 Sprout Channel Cubby Speaker Replacement: paso 3, imagen 2 de 2
    • Remove black tape.
    • Disconnect the red and black wires which are soldered to the device. Make sure to not remove the wires that connect to the battery.
    • Replace the speaker.
    • Follow the steps in reverse order (be sure to solder the wires correctly) to install it.
Conclusión
Una persona más ha completado esta guía.
jasen biggins
Miembro Desde 08/26/15
741 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 14-101, Meier Fall 2015 Miembro de USF Tampa, Team 14-101, Meier Fall 2015
USFT-MEIER-F15S14G101
4 Miembros
12 Guías creadas
2 comentarios
Jasen, where can I purchase the replacement speaker for the Sprout?
william mulligan - Contestar
There is no way that I would want to take apart a new tablet to replaceor repair the speakers. Why not install it correctly the first time? Appears to be an ongoing issue.
Edreia Jones - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 6
Ultimos 30 días: 21
Todo El Tiempo: 1,042
