Saltar al contenido principal
Sprint Sanyo RL-4920 Vibrator Motor Replacement
Qué necesitas
  1. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Back of Phone: paso 1, imagen 1 de 1
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Remove Battery Pack: paso 2, imagen 1 de 2 Sprint Sanyo RL-4920 Vibrator Motor Replacement, Remove Battery Pack: paso 2, imagen 2 de 2
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Screws: paso 3, imagen 1 de 2 Sprint Sanyo RL-4920 Vibrator Motor Replacement, Screws: paso 3, imagen 2 de 2
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Separate Cases: paso 4, imagen 1 de 1
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Separate Cases: paso 5, imagen 1 de 1
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Vibrator Motor Replacement, The Front Case: paso 6, imagen 1 de 1
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Display: paso 7, imagen 1 de 2 Sprint Sanyo RL-4920 Vibrator Motor Replacement, Display: paso 7, imagen 2 de 2
    • Locate the 4 white clips of the dispaly.
  8. Sprint Sanyo RL-4920 Vibrator Motor Replacement: paso 8, imagen 1 de 2 Sprint Sanyo RL-4920 Vibrator Motor Replacement: paso 8, imagen 2 de 2
    • Using the plastic opening tool, pull the white clips of the display away from the printed circuit board to unclip display.
  9. Sprint Sanyo RL-4920 Vibrator Motor Replacement: paso 9, imagen 1 de 2 Sprint Sanyo RL-4920 Vibrator Motor Replacement: paso 9, imagen 2 de 2
    • Grasp the display on both sides and carefully pull the display off of the printed circuit board.
  10. Sprint Sanyo RL-4920 Vibrator Motor Replacement: paso 10, imagen 1 de 2 Sprint Sanyo RL-4920 Vibrator Motor Replacement: paso 10, imagen 2 de 2
    • Using the plastic opening tool, carefully remove the yellow film covering the display connector.
    • Do not damage the yellow film. Ensure that it stays in one piece and does not tear.
  11. Sprint Sanyo RL-4920 Vibrator Motor Replacement, Vibrator Motor: paso 11, imagen 1 de 1
    • Use a Phillips-head screw bit to remove the screw under the yellow film
  12. Sprint Sanyo RL-4920 Vibrator Motor Replacement: paso 12, imagen 1 de 3 Sprint Sanyo RL-4920 Vibrator Motor Replacement: paso 12, imagen 2 de 3 Sprint Sanyo RL-4920 Vibrator Motor Replacement: paso 12, imagen 3 de 3
    • Use the spudger tool to pry the latches ways from the circuit board
    • Detach the metal casing from the circuit board
  13. Sprint Sanyo RL-4920 Vibrator Motor Replacement: paso 13, imagen 1 de 2 Sprint Sanyo RL-4920 Vibrator Motor Replacement: paso 13, imagen 2 de 2
    • Remove wires attaching vibrator motor to circuit board gently so as not to damage them
  14. Sprint Sanyo RL-4920 Vibrator Motor Replacement: paso 14, imagen 1 de 3 Sprint Sanyo RL-4920 Vibrator Motor Replacement: paso 14, imagen 2 de 3 Sprint Sanyo RL-4920 Vibrator Motor Replacement: paso 14, imagen 3 de 3
    • Once the metal casing is removed from the circuit board take it and locate the vibrator motor on the top side of the casing
    • Use the spudger tool to gently pry the vibrator motor out of its protective shell
  15. Sprint Sanyo RL-4920 Vibrator Motor Replacement: paso 15, imagen 1 de 1
    • With the vibrator motor completely removed, you can now replace it with a new one
Conclusión
Una persona más ha completado esta guía.
Austin Shores
Miembro Desde 10/18/13
301 Reputación
3 Guías creadas
Equipo
Clemson, Team 13-5, Benson Fall 2013 Miembro de Clemson, Team 13-5, Benson Fall 2013
CLEM-BENSON-F13S13G5
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 13
Todo El Tiempo: 301
