Saltar al contenido principal
Sprint Sanyo RL-4920 Speaker Replacement
Qué necesitas
  1. Sprint Sanyo RL-4920 Speaker Replacement, Back of Phone: paso 1, imagen 1 de 1
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Speaker Replacement, Remove Battery Pack: paso 2, imagen 1 de 2 Sprint Sanyo RL-4920 Speaker Replacement, Remove Battery Pack: paso 2, imagen 2 de 2
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Speaker Replacement, Screws: paso 3, imagen 1 de 2 Sprint Sanyo RL-4920 Speaker Replacement, Screws: paso 3, imagen 2 de 2
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Speaker Replacement, Separate Cases: paso 4, imagen 1 de 1
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Speaker Replacement, Separate Cases: paso 5, imagen 1 de 1
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Speaker Replacement, The Front Case: paso 6, imagen 1 de 1
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Speaker Replacement, Screws: paso 7, imagen 1 de 2 Sprint Sanyo RL-4920 Speaker Replacement, Screws: paso 7, imagen 2 de 2
    • Locate the three screws securing the speaker.
    • Use a Phillips-head screw bit to unscrew the screws
  8. Sprint Sanyo RL-4920 Speaker Replacement, Replace Speaker: paso 8, imagen 1 de 1
    • Remove the speaker.
    • Replace with new speaker.
    • Secure new speaker with screws and reassemble phone.
Conclusión
Austin Shores
Miembro Desde 10/18/13
301 Reputación
3 Guías creadas
Equipo
Clemson, Team 13-5, Benson Fall 2013 Miembro de Clemson, Team 13-5, Benson Fall 2013
CLEM-BENSON-F13S13G5
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 171
