Saltar al contenido principal
Sprint Sanyo RL-4920 Display Replacement
Qué necesitas
  1. Sprint Sanyo RL-4920 Display Replacement, Back of Phone: paso 1, imagen 1 de 1
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Display Replacement, Remove Battery Pack: paso 2, imagen 1 de 2 Sprint Sanyo RL-4920 Display Replacement, Remove Battery Pack: paso 2, imagen 2 de 2
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Display Replacement, Screws: paso 3, imagen 1 de 2 Sprint Sanyo RL-4920 Display Replacement, Screws: paso 3, imagen 2 de 2
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Display Replacement, Separate Cases: paso 4, imagen 1 de 1
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Display Replacement, Separate Cases: paso 5, imagen 1 de 1
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Display Replacement, The Front Case: paso 6, imagen 1 de 1
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Display Replacement, Display: paso 7, imagen 1 de 2 Sprint Sanyo RL-4920 Display Replacement, Display: paso 7, imagen 2 de 2
    • Locate the 4 white clips of the dispaly.
  8. Sprint Sanyo RL-4920 Display Replacement: paso 8, imagen 1 de 2 Sprint Sanyo RL-4920 Display Replacement: paso 8, imagen 2 de 2
    • Using the plastic opening tool, pull the white clips of the display away from the printed circuit board to unclip display.
  9. Sprint Sanyo RL-4920 Display Replacement: paso 9, imagen 1 de 2 Sprint Sanyo RL-4920 Display Replacement: paso 9, imagen 2 de 2
    • Grasp the display on both sides and carefully pull the display off of the printed circuit board.
  10. Sprint Sanyo RL-4920 Display Replacement: paso 10, imagen 1 de 2 Sprint Sanyo RL-4920 Display Replacement: paso 10, imagen 2 de 2
    • Using the plastic opening tool, carefully remove the yellow film covering the display connector.
    • Do not damage the yellow film. Ensure that it stays in one piece and does not tear.
Conclusión
Una persona más ha completado esta guía.
Equipo
Clemson, Team 13-5, Benson Fall 2013 Miembro de Clemson, Team 13-5, Benson Fall 2013
CLEM-BENSON-F13S13G5
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 242
