Saltar al contenido principal
Spiral Bound Notebook Cover Replacement
Qué necesitas
  1. Spiral Bound Notebook Cover Replacement, Cover: paso 1, imagen 1 de 2 Spiral Bound Notebook Cover Replacement, Cover: paso 1, imagen 2 de 2
    • Use a binder clip on either end to hold the paper block together, excluding the damaged cover.
  2. Spiral Bound Notebook Cover Replacement: paso 2, imagen 1 de 3 Spiral Bound Notebook Cover Replacement: paso 2, imagen 2 de 3 Spiral Bound Notebook Cover Replacement: paso 2, imagen 3 de 3
    • Uncoil the free end of the spiral.
  3. Spiral Bound Notebook Cover Replacement: paso 3, imagen 1 de 3 Spiral Bound Notebook Cover Replacement: paso 3, imagen 2 de 3 Spiral Bound Notebook Cover Replacement: paso 3, imagen 3 de 3
    • Push the spiral end back through the binding hole and pull it out.
  4. Spiral Bound Notebook Cover Replacement: paso 4, imagen 1 de 1
    • Repeat previous step until spiral is removed.
  5. Spiral Bound Notebook Cover Replacement: paso 5, imagen 1 de 1
    • Take the damaged cover and place it over the cardstock, aligning them at the edges.
  6. Spiral Bound Notebook Cover Replacement: paso 6, imagen 1 de 3 Spiral Bound Notebook Cover Replacement: paso 6, imagen 2 de 3 Spiral Bound Notebook Cover Replacement: paso 6, imagen 3 de 3
    • Trace the cover edges.
  7. Spiral Bound Notebook Cover Replacement: paso 7, imagen 1 de 2 Spiral Bound Notebook Cover Replacement: paso 7, imagen 2 de 2
    • Trace the cover binding holes.
  8. Spiral Bound Notebook Cover Replacement: paso 8, imagen 1 de 3 Spiral Bound Notebook Cover Replacement: paso 8, imagen 2 de 3 Spiral Bound Notebook Cover Replacement: paso 8, imagen 3 de 3
    • Using a hole punch, punch out the traced holes on the cardstock sheet.
  9. Spiral Bound Notebook Cover Replacement: paso 9, imagen 1 de 3 Spiral Bound Notebook Cover Replacement: paso 9, imagen 2 de 3 Spiral Bound Notebook Cover Replacement: paso 9, imagen 3 de 3
    • Cut off the traced edges on the cardstock sheet.
  10. Spiral Bound Notebook Cover Replacement: paso 10, imagen 1 de 2 Spiral Bound Notebook Cover Replacement: paso 10, imagen 2 de 2
    • Without removing the binding clip, open it and slide the cardstock onto the paper block while making sure their holes aligned.
  11. Spiral Bound Notebook Cover Replacement: paso 11, imagen 1 de 3 Spiral Bound Notebook Cover Replacement: paso 11, imagen 2 de 3 Spiral Bound Notebook Cover Replacement: paso 11, imagen 3 de 3
    • Perform Steps 1 through 4 in reverse to complete the replacement.
Conclusión
To reassemble your device, follow instructions 1 - 4 in reverse order.
Una persona más ha completado esta guía.
Abel Mbaziira
Miembro Desde 01/18/23
220 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 31
Ultimos 30 días: 134
Todo El Tiempo: 2,074
