Saltar al contenido principal
Spin Master Hatchimal Draggle Wheels Replacement
Qué necesitas
  1. Spin Master Hatchimal Draggle Wheels Replacement, Plastic Wing Replacement: paso 1, imagen 1 de 1
    • lay the Hatchimal on its side.
  2. Spin Master Hatchimal Draggle Wheels Replacement: paso 2, imagen 1 de 1
    • Using the plastic opening tool, push in on the purple clip.
  3. Spin Master Hatchimal Draggle Wheels Replacement: paso 3, imagen 1 de 1
    • Pull the wing off of the hatchimal.
    • The wing should come off with little resistance.
  4. Spin Master Hatchimal Draggle Wheels Replacement, Fur Replacement: paso 4, imagen 1 de 2 Spin Master Hatchimal Draggle Wheels Replacement, Fur Replacement: paso 4, imagen 2 de 2
    • Cut the fur retaining zip-tie with a pair of scissors.
  5. Spin Master Hatchimal Draggle Wheels Replacement: paso 5, imagen 1 de 2 Spin Master Hatchimal Draggle Wheels Replacement: paso 5, imagen 2 de 2
    • Lift the fur up until it can't go further.
  6. Spin Master Hatchimal Draggle Wheels Replacement: paso 6, imagen 1 de 3 Spin Master Hatchimal Draggle Wheels Replacement: paso 6, imagen 2 de 3 Spin Master Hatchimal Draggle Wheels Replacement: paso 6, imagen 3 de 3
    • Use the spudger tool to push up on the black clip to free it.
    • Pull the clip out.
  7. Spin Master Hatchimal Draggle Wheels Replacement: paso 7, imagen 1 de 3 Spin Master Hatchimal Draggle Wheels Replacement: paso 7, imagen 2 de 3 Spin Master Hatchimal Draggle Wheels Replacement: paso 7, imagen 3 de 3
    • Lift fur up to reveal the next set of clips.
    • Insert a spudger to push up on the black clip to free it.
    • Pull out the clip.
  8. Spin Master Hatchimal Draggle Wheels Replacement: paso 8, imagen 1 de 2 Spin Master Hatchimal Draggle Wheels Replacement: paso 8, imagen 2 de 2
    • Lift the fur up and over the Hatchimals Head.
    • Remove the six 12mm Phillips #00 screws from then body.
  9. Spin Master Hatchimal Draggle Wheels Replacement: paso 9, imagen 1 de 2 Spin Master Hatchimal Draggle Wheels Replacement: paso 9, imagen 2 de 2
    • Pull the casing apart.
    • Remove the yellow speaker cable.
  10. Spin Master Hatchimal Draggle Wheels Replacement: paso 10, imagen 1 de 3 Spin Master Hatchimal Draggle Wheels Replacement: paso 10, imagen 2 de 3 Spin Master Hatchimal Draggle Wheels Replacement: paso 10, imagen 3 de 3
    • Remove the three 7mm Phillips #00 screws from the head.
    • Remove the wheel base and the circuit board carefully not to damage the spring.
  11. Spin Master Hatchimal Draggle Wheels Replacement: paso 11, imagen 1 de 2 Spin Master Hatchimal Draggle Wheels Replacement: paso 11, imagen 2 de 2
    • Push the six black fur clips out using the spudger.
    • Remove the fur completely.
  12. Spin Master Hatchimal Draggle Wheels Replacement, Wheel Replacement: paso 12, imagen 1 de 2 Spin Master Hatchimal Draggle Wheels Replacement, Wheel Replacement: paso 12, imagen 2 de 2
    • Lift up and remove the light blue plastic casing.
  13. Spin Master Hatchimal Draggle Wheels Replacement: paso 13, imagen 1 de 2 Spin Master Hatchimal Draggle Wheels Replacement: paso 13, imagen 2 de 2
    • Remove the six 7mm Phillips #00 screws.
  14. Spin Master Hatchimal Draggle Wheels Replacement: paso 14, imagen 1 de 2 Spin Master Hatchimal Draggle Wheels Replacement: paso 14, imagen 2 de 2
    • Remove the purple plastic casing. It should come off with little resistance.
    • Remove the wheel.
Conclusión
2 personas más completaron esta guía.
Humaid Alhajri
Miembro Desde 02/14/18
115 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S1-G5, Nance Spring 2018 Miembro de USF Tampa, Team S1-G5, Nance Spring 2018
USFT-NANCE-S18S1G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 1,124
