Saltar al contenido principal
Speed Switch
Qué necesitas
  1. Speed Switch, Switch: paso 1, imagen 1 de 2 Speed Switch, Switch: paso 1, imagen 2 de 2
    • Use a phillips head screwdriver to unscrew the following 8 screws:
    • One 24mm Phillips screw
    • Six 16mm Phillips screws
    • One 9mm Phillips screw
    • Turn the drill to the other side and unscrew the marked screw using the same phillips head screwdriver. Place it with the other removed screws.
    • Keep all screws organized on a magnetic mat after removal.
  2. Speed Switch: paso 2, imagen 1 de 3 Speed Switch: paso 2, imagen 2 de 3 Speed Switch: paso 2, imagen 3 de 3
    • Carefully remove the plastic drill casing by pulling it apart.
    • When separating the drill casing, the black plastic speed switch covering will be removed from the drill automatically.
  3. Speed Switch: paso 3, imagen 1 de 2 Speed Switch: paso 3, imagen 2 de 2
    • Gently remove the orange plastic speed switch from the drill. It is located right above the motor.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 10
Todo El Tiempo: 990
