Saltar al contenido principal
Speaker Bose SoundDock Motherboard Replacement
Qué necesitas
  1. Speaker Bose SoundDock Motherboard Replacement, Bose SoundDock Motherboard: paso 1, imagen 1 de 2 Speaker Bose SoundDock Motherboard Replacement, Bose SoundDock Motherboard: paso 1, imagen 2 de 2
    • Remove the battery by pressing your finger down on the center button and twisting it counter-clockwise.
    • Remove battery and set it aside.
  2. Speaker Bose SoundDock Motherboard Replacement: paso 2, imagen 1 de 1
    • Use a plastic scraper to remove the rubber gasket from the bottom of speaker system and set it aside.
  3. Speaker Bose SoundDock Motherboard Replacement: paso 3, imagen 1 de 1
    • Use a standard sized Phillips Screwdriver to remove the four screws on the bottom of the speaker system.
  4. Speaker Bose SoundDock Motherboard Replacement: paso 4, imagen 1 de 1
    • Using a smaller flat head screw driver, unscrew the semi-circle plate from bottom to expose the motherboard.
    • Once the components are unscrewed, the plastic dock frame may fall out.
  5. Speaker Bose SoundDock Motherboard Replacement: paso 5, imagen 1 de 1
    • Gently pull both ribbon cables out of the motherboard.
  6. Speaker Bose SoundDock Motherboard Replacement: paso 6, imagen 1 de 1
    • Replace it with new motherboard by plugging in the thinner wire into the small slot, and the larger wire into the wider slot.
    • Reverse steps 1 through 4 to reassemble dock.
Conclusión
Dalton Alexandre
Miembro Desde 02/24/15
123 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 24-5, Green Winter 2015 Miembro de Cal Poly, Team 24-5, Green Winter 2015
CPSU-GREEN-W15S24G5
3 Miembros
4 Guías creadas
Un comentario
Where can you buy the motherboard?
Steffen Jensen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 3,235
