Saltar al contenido principal
SoundBot SB571 Speaker Grille
Qué necesitas
  1. SoundBot SB571 Speaker Grille, Speaker Grille: paso 1, imagen 1 de 1
    • Before disassembling the speaker, make sure it is powered off.
    • Place the speaker on a flat surface.
    • Take your blue plastic opening tool and remove the plastic cover.
  2. SoundBot SB571 Speaker Grille: paso 2, imagen 1 de 3 SoundBot SB571 Speaker Grille: paso 2, imagen 2 de 3 SoundBot SB571 Speaker Grille: paso 2, imagen 3 de 3
    • Orient the speaker so that the top is facing up.
    • Using your Phillips PH0 screwdriver unscrew the 14, 0.6cm screws from the device along the speaker grille.
  3. SoundBot SB571 Speaker Grille: paso 3, imagen 1 de 2 SoundBot SB571 Speaker Grille: paso 3, imagen 2 de 2
    • Reorient the speaker so the grille is facing you.
    • Using the blue plastic opening tool, prop open the metal grille.
    • Now the speaker grille is completely removed from the device and it can be replaced.
Conclusión
2 personas más completaron esta guía.
Yana
Miembro Desde 02/09/16
645 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 2-50, Cagle Spring 2016 Miembro de USF Tampa, Team 2-50, Cagle Spring 2016
USFT-CAGLE-S16S2G50
4 Miembros
2 Guías creadas
Un comentario
Sir my soundbot sb571 one side sound doesnot work how could i do for its repairing.
Ram Meena - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 17
Todo El Tiempo: 1,638
