Introducción
If your sound card is damaged or broken or you're having trouble with the sound within your laptop, replace the sound card using this guide.
  1. Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop. Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
    • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  2. Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it. Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
    • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Use the tweezers to remove the two connecting wires.
    • Use the tweezers to remove the two connecting wires.
  5. Using the Phillips #1 screwdriver, remove the two 2.5mm screws holding down the card.
    • Using the Phillips #1 screwdriver, remove the two 2.5mm screws holding down the card.
  6. Lift and pull the sound card away from the computer.
    • Lift and pull the sound card away from the computer.
Conclusión
Armani Tayeh
Miembro Desde 19/03/18
411 Reputación
4 Guías creadas
Equipo
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 47
