Saltar al contenido principal
Sophix TAB-730g Battery Replacement
Qué necesitas
  1. Sophix TAB-730g Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back cover to gain access to the mother board.
    • Unscrew, with a 000 Philip's screwdriver, the 3.547 mm long screw located at the bottom of your tablet.
  2. Sophix TAB-730g Battery Replacement: paso 2, imagen 1 de 1
    • Firmly slide the cover in the direction indicated by the arrow, away from the ports, with your hand to remove the back cover.
  3. Sophix TAB-730g Battery Replacement: paso 3, imagen 1 de 1
    • Desolder the two wires connecting the battery to the mother board.
  4. Sophix TAB-730g Battery Replacement: paso 4, imagen 1 de 1
    • Gently pry the battery off the back of the device using some force.
    • There is adhesive keeping the battery attached so a decent amount of force may need to be applied.
Conclusión
2 personas más completaron esta guía.
JT Hiquet
Miembro Desde 09/29/16
333 Reputación
3 Guías creadas
Equipo
IUPUI, Team 2-3, Harley Fall 2016 Miembro de IUPUI, Team 2-3, Harley Fall 2016
IUPUI-HARLEY-F16S2G3
4 Miembros
6 Guías creadas
Un comentario
[|how do you know if the problem is or is not the battery?]
Don Taylor - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 8
Todo El Tiempo: 365
