Qué necesitas
Place the projector upside-down to access the screws on the bottom.
Remove five 9mm long screws with a Phillips 1 screwdriver.
Remove five 9mm screws with a Phillips 1 screwdriver
Remove one 11mm screws with a Phillips one screwdriver
To remove the ribbon cables, lift up on the black hinge with a fingernail or the tip of your spudger.
Now, use a spudger or a barbecue skewer to lift the cable out.
Casi Terminas!
Conclusión
