Saltar al contenido principal
Sony-BDP-SX1000 Battery Replacement
Qué necesitas
  1. Aviso: los pasos 1-2 provienen de una guía que está marcada como "En progreso".
    Sony-BDP-SX1000 Battery Replacement, How To Open The Device: paso 1, imagen 1 de 2 Sony-BDP-SX1000 Battery Replacement, How To Open The Device: paso 1, imagen 2 de 2
    • Flip the Sony BDP-SX1000 over so that the underside is facing up.
    • Remove the four 2mm Phillips #0 screws at the top of the device.
    • Remove the rest of the J0mm Phillips #0 screws from the device.
  2. Sony-BDP-SX1000 Battery Replacement: paso 2, imagen 1 de 2 Sony-BDP-SX1000 Battery Replacement: paso 2, imagen 2 de 2
    • Take out the seals at the bottom and at the corners with edge of screwdriver. Remove the J0mm Phillips #0 screws under the seals.
    • Remove the back lid of the Sony BDP-SX1000 so that you can now see the inside of the device. The two lids are attached by two wires. The small wire on right side of the top lid goes on right side of bottom lid or on the black connector. The big wire on left side of the top lid goes on left side of the bottom lid or on white connector.
  3. Sony-BDP-SX1000 Battery Replacement, Battery: paso 3, imagen 1 de 2 Sony-BDP-SX1000 Battery Replacement, Battery: paso 3, imagen 2 de 2
    • The battery can be found at the bottom of the device.
    • Remove the battery by removing the white connector.
Conclusión
Equipo
UC Davis, Team S4-G2, Lore Fall 2018 Miembro de UC Davis, Team S4-G2, Lore Fall 2018
UCD-LORE-F18S4G2
Miembros de 3
3 Guías creadas
Un comentario
Any one know where to find replacement batteries?
ledude71 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 18
Ultimos 30 días: 43
Todo El Tiempo: 1,257
