Saltar al contenido principal
Sony Xplod CDX-MP30 Front Screen Motherboard Replacement
Qué necesitas
  1. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: paso 1, imagen 1 de 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: paso 1, imagen 2 de 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: paso 1, imagen 3 de 3
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Screen Motherboard: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Phillips #0 Screwdriver
    $5.49
    Comprar
  3. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: paso 3, imagen 1 de 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: paso 3, imagen 2 de 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: paso 3, imagen 3 de 3
    • Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture.
  4. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: paso 4, imagen 1 de 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: paso 4, imagen 2 de 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: paso 4, imagen 3 de 3
    Heavy-Duty Spudger
    Comprar
    • Insert the flat end of the Heavy-duty Spudger into the opening you created.
    • Slide it to the right carefully, until you feel the screen pop off.
    • Make sure you keep the face of the screen pointed down as you carefully lift off the freed black portion of the screen - as shown in the picture.
  5. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: paso 5, imagen 1 de 2 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: paso 5, imagen 2 de 2
    • Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
  6. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: paso 6, imagen 1 de 1
    • To remove the LCD, please refer to the iFixit soldering guide.
    • Once the LCD screen is removed, you have unrestricted access to the front screen motherboard.
Conclusión
Chao Chen
Miembro Desde 10/04/11
79 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 5-35, Amido Fall 2011 Miembro de Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 5,601
