Introducción
Make sure you can explore the Xplod very well.
Partes
No se requieren partes.
  1. Press down the release button on the bottom left corner of the face plate. Then remove the face plate carefully. Then remove the face plate carefully.
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture. Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture. Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture.
    • Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture.
    • Insert the flat end of the Heavy-duty Spudger into the opening you created.
    • Slide it to the right carefully, until you feel the screen pop off.
    • Make sure you keep the face of the screen pointed down as you carefully lift off the freed black portion of the screen - as shown in the picture.
  4. Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen. Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
    • Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
  5. To remove the LCD, please refer to the iFixit soldering guide.
    • To remove the LCD, please refer to the iFixit soldering guide.
    • Once the LCD screen is removed, you have unrestricted access to the front screen motherboard.
Conclusión
Chao Chen
Miembro Desde 04/10/11
79 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 5-35, Amido Fall 2011 Miembro de Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
4 Miembros
8 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 7
Últimos 30 Días: 33
Todo El Tiempo: 4,761
