Saltar al contenido principal
Sony Xperia Z5 Charging Port Flex Replacement
Qué necesitas
  1. Sony Xperia Z5 Charging Port Flex Replacement, Charging Port Flex: paso 1, imagen 1 de 2 Sony Xperia Z5 Charging Port Flex Replacement, Charging Port Flex: paso 1, imagen 2 de 2
    • Remove SIM card tray.
  2. Sony Xperia Z5 Charging Port Flex Replacement: paso 2, imagen 1 de 2 Sony Xperia Z5 Charging Port Flex Replacement: paso 2, imagen 2 de 2
    • Heat the back cover to soften the adhesive sticker.
    • Place the suction cup and inert metal opening tool to open a gap from top side.
  3. Sony Xperia Z5 Charging Port Flex Replacement: paso 3, imagen 1 de 3 Sony Xperia Z5 Charging Port Flex Replacement: paso 3, imagen 2 de 3 Sony Xperia Z5 Charging Port Flex Replacement: paso 3, imagen 3 de 3
    • Insert the guitar pick and slide it to cut the adhesive sticker underneath.
    • Remove back cover.
  4. Sony Xperia Z5 Charging Port Flex Replacement: paso 4, imagen 1 de 3 Sony Xperia Z5 Charging Port Flex Replacement: paso 4, imagen 2 de 3 Sony Xperia Z5 Charging Port Flex Replacement: paso 4, imagen 3 de 3
    • Release battery connector and pull off the adhesive tape underneath.
    • Pry up battery.
  5. Sony Xperia Z5 Charging Port Flex Replacement: paso 5, imagen 1 de 3 Sony Xperia Z5 Charging Port Flex Replacement: paso 5, imagen 2 de 3 Sony Xperia Z5 Charging Port Flex Replacement: paso 5, imagen 3 de 3
    • Release rear camera connector, front camera connector, audio jack flex connector and main flex connector on the motherboard and remove the screws there.
    • Take away the plastic bracket.
  6. Sony Xperia Z5 Charging Port Flex Replacement: paso 6, imagen 1 de 3 Sony Xperia Z5 Charging Port Flex Replacement: paso 6, imagen 2 de 3 Sony Xperia Z5 Charging Port Flex Replacement: paso 6, imagen 3 de 3
    • Remove metal cover securing loudspeaker and twist off screws.
    • Pry up and loosen the bottom side of main flex assembly.
  7. Sony Xperia Z5 Charging Port Flex Replacement: paso 7, imagen 1 de 2 Sony Xperia Z5 Charging Port Flex Replacement: paso 7, imagen 2 de 2
    • Remove main flex. ( Attention: the fingerprint sensor connector is here, be careful to loosen it)
  8. Sony Xperia Z5 Charging Port Flex Replacement: paso 8, imagen 1 de 2 Sony Xperia Z5 Charging Port Flex Replacement: paso 8, imagen 2 de 2
    • This is main flex assembly. (It comes with loudspeaker and vibration motor )
  9. Sony Xperia Z5 Charging Port Flex Replacement: paso 9, imagen 1 de 2 Sony Xperia Z5 Charging Port Flex Replacement: paso 9, imagen 2 de 2
    • Remove rear camera.
  10. Sony Xperia Z5 Charging Port Flex Replacement: paso 10, imagen 1 de 3 Sony Xperia Z5 Charging Port Flex Replacement: paso 10, imagen 2 de 3 Sony Xperia Z5 Charging Port Flex Replacement: paso 10, imagen 3 de 3
    • Remove that securing bracket, then remove front camera.
  11. Sony Xperia Z5 Charging Port Flex Replacement: paso 11, imagen 1 de 3 Sony Xperia Z5 Charging Port Flex Replacement: paso 11, imagen 2 de 3 Sony Xperia Z5 Charging Port Flex Replacement: paso 11, imagen 3 de 3
    • Release connectors on the motherboard. Remove motherboard.
  12. Sony Xperia Z5 Charging Port Flex Replacement: paso 12, imagen 1 de 3 Sony Xperia Z5 Charging Port Flex Replacement: paso 12, imagen 2 de 3 Sony Xperia Z5 Charging Port Flex Replacement: paso 12, imagen 3 de 3
    • Remove charging port flex.
Conclusión
14 personas más completaron esta guía.
Lenka
Miembro Desde 11/06/15
2,376 Reputación
6 Guías creadas
3 comentarios
How about the waterproof adhesive ?
Tess - Contestar
Would you have a step by step method to replace it ?
Tess - Contestar
I can’t turn my phone back on. Any clues?
Bjoern Aeschlimann - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 25
Todo El Tiempo: 17,506
