Saltar al contenido principal
Sony Xperia Z5 Battery Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Sony Xperia Z5 Battery Replacement, Battery: paso 1, imagen 1 de 2 Sony Xperia Z5 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove SIM card tray.
  2. Sony Xperia Z5 Battery Replacement: paso 2, imagen 1 de 2 Sony Xperia Z5 Battery Replacement: paso 2, imagen 2 de 2
    • Heat the back cover to soften the adhesive.
    • Place the suction cup and insert metal opening tool to open a gap from top side.
  3. Sony Xperia Z5 Battery Replacement: paso 3, imagen 1 de 3 Sony Xperia Z5 Battery Replacement: paso 3, imagen 2 de 3 Sony Xperia Z5 Battery Replacement: paso 3, imagen 3 de 3
    • Insert the guitar picks and slide it to cut the adhesive underneath.
    • Remove back cover.
  4. Sony Xperia Z5 Battery Replacement: paso 4, imagen 1 de 3 Sony Xperia Z5 Battery Replacement: paso 4, imagen 2 de 3 Sony Xperia Z5 Battery Replacement: paso 4, imagen 3 de 3
    • Release battery connector and pull off the adhesive tape underneath.
    • Pry up battery.
Linea de Meta
25 personas más completaron esta guía.
Lenka
Miembro Desde 11/06/15
2,376 Reputación
6 Guías creadas
7 comentarios
I missed the part about the adhesive for the battery and broke the tabs off. Made it slightly harder but I got it. Thanks for the instructions. Now I can get all my things off of it
Braydon - Contestar
can you put a link to where i could buy the battery from? it would be helpful, thank you
ido r - Contestar
worked a treat - simple straightforward - thanks!!
John Turnbull - Contestar
umm how do you put the cover back on?
Dulantha Fernando - Contestar
Just push and then consolidate with heat, I used hair dryer.
Jorge García Laosa -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 52,870
