Saltar al contenido principal
Sony Xperia Z3 USB cover and SD card slot cover Replacement
Resumen del Video
Sony Xperia Z3 USB Port Cover + SD/SIM Flap Replacement
  1. Sony Xperia Z3 USB cover and SD card slot cover Replacement, USB cover and SD card slot cover: paso 1, imagen 1 de 3 Sony Xperia Z3 USB cover and SD card slot cover Replacement, USB cover and SD card slot cover: paso 1, imagen 2 de 3 Sony Xperia Z3 USB cover and SD card slot cover Replacement, USB cover and SD card slot cover: paso 1, imagen 3 de 3
    • Use your fingers to pull firmly on the broken USB port cover until it pops out.
    • Remove the USB port cover.
  2. Sony Xperia Z3 USB cover and SD card slot cover Replacement: paso 2, imagen 1 de 3 Sony Xperia Z3 USB cover and SD card slot cover Replacement: paso 2, imagen 2 de 3 Sony Xperia Z3 USB cover and SD card slot cover Replacement: paso 2, imagen 3 de 3
    • Use your fingers to firmly pull out the SD/SIM card flap.
    • Remove the SD/SIM card flap.
Conclusión
13 personas más completaron esta guía.
Sophia
Miembro Desde 03/25/14
43,810 Reputación
62 Guías creadas
4 comentarios
Does Z3 and Z3V have same size USB flaps?
Sudip Shrestha - Contestar
i need for model D6633
Umer Farooq -
ineed both same size
Umer Farooq -
Part of the white plastic end connected to the old USB charge port cover flap on my Sony XperiaZ3v is still inside my phone. How do I get that broken piece out of the phone before installing the new USB cover in the phone?
Narda Dawidowicz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 49
Todo El Tiempo: 21,184
