Saltar al contenido principal
Sony Xperia Z3 Dual Loudspeaker Assembly Replacement
Qué necesitas
Resumen del Video
  1. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: paso 1, imagen 1 de 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: paso 1, imagen 2 de 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: paso 1, imagen 3 de 3
    • Heat to soften back cover sticker.
    • Place the suction cup and try to open a gap.
    • Insert the guitar pick into the gap.
  2. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: paso 2, imagen 1 de 2 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: paso 2, imagen 2 de 2
    • Slide the guitar pick to cut the sticker and remove the back cover.
  3. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: paso 3, imagen 1 de 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: paso 3, imagen 2 de 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: paso 3, imagen 3 de 3
    • Remove two screws by Philips screwdriver.
    • Release all the connectors connecting with loudspeaker assembly.
    • Remove the small vibrator securing bracket.
  4. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: paso 4, imagen 1 de 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: paso 4, imagen 2 de 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: paso 4, imagen 3 de 3
    • Remove the securing cover. It's thin and weak, please be careful when remove it.
  5. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: paso 5, imagen 1 de 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: paso 5, imagen 2 de 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: paso 5, imagen 3 de 3
    • Pry up the assembly and carry it out.
  6. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: paso 6, imagen 1 de 2 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: paso 6, imagen 2 de 2
    • Remove the loudspeaker assembly finally. Be careful with the flex beside assembly.
Conclusión
4 personas más completaron esta guía.
Sophia
Miembro Desde 03/25/14
43,810 Reputación
62 Guías creadas
2 comentarios
this is all good but is there a link to the part ?
morten hundevad - Contestar
EBay search Sony z3 replacement loud speaker cost's around £3-£5
Martin Lb -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 4,413
