Saltar al contenido principal
Sony Xperia Z3 Dual Headphone Jack Replacement
Qué necesitas
  1. Sony Xperia Z3 Dual Headphone Jack Replacement, Headphone Jack: paso 1, imagen 1 de 1
    • Power off the phone and remove two SIM card trays before headphone jack replacement.
  2. Sony Xperia Z3 Dual Headphone Jack Replacement: paso 2, imagen 1 de 3 Sony Xperia Z3 Dual Headphone Jack Replacement: paso 2, imagen 2 de 3 Sony Xperia Z3 Dual Headphone Jack Replacement: paso 2, imagen 3 de 3
    • Heat to soften back cover adhesive sticker.
    • Use suction cup to open a gap and insert into the guitar pick.
    • Slide the guitar pick to cut the sticker all around every side.
  3. Sony Xperia Z3 Dual Headphone Jack Replacement: paso 3, imagen 1 de 1
    • Remove back cover.
  4. Sony Xperia Z3 Dual Headphone Jack Replacement: paso 4, imagen 1 de 3 Sony Xperia Z3 Dual Headphone Jack Replacement: paso 4, imagen 2 de 3 Sony Xperia Z3 Dual Headphone Jack Replacement: paso 4, imagen 3 de 3
    • Remove battery easily.
  5. Sony Xperia Z3 Dual Headphone Jack Replacement: paso 5, imagen 1 de 1
    • Twist off two screws by Philips screwdriver at first.
  6. Sony Xperia Z3 Dual Headphone Jack Replacement: paso 6, imagen 1 de 3 Sony Xperia Z3 Dual Headphone Jack Replacement: paso 6, imagen 2 de 3 Sony Xperia Z3 Dual Headphone Jack Replacement: paso 6, imagen 3 de 3
    • Remove three pieces of securing bracket.
  7. Sony Xperia Z3 Dual Headphone Jack Replacement: paso 7, imagen 1 de 3 Sony Xperia Z3 Dual Headphone Jack Replacement: paso 7, imagen 2 de 3 Sony Xperia Z3 Dual Headphone Jack Replacement: paso 7, imagen 3 de 3
    • Release all the connectors connecting with motherboard.
    • Pry it up from left side. Please be careful with some hidden keys, they held the motherboard really tightly.
  8. Sony Xperia Z3 Dual Headphone Jack Replacement: paso 8, imagen 1 de 2 Sony Xperia Z3 Dual Headphone Jack Replacement: paso 8, imagen 2 de 2
    • Remove securing cover beside headphone jack.
  9. Sony Xperia Z3 Dual Headphone Jack Replacement: paso 9, imagen 1 de 3 Sony Xperia Z3 Dual Headphone Jack Replacement: paso 9, imagen 2 de 3 Sony Xperia Z3 Dual Headphone Jack Replacement: paso 9, imagen 3 de 3
    • Remove the flex cover on the headphone jack. It's a part of the assembly and comes with denoise MIC and sensors.
    • Cut the adhesive sticker between headphone jack and midframe.
    • Remove headphone jack finally.
Conclusión
4 personas más completaron esta guía.
Sophia
Miembro Desde 03/25/14
43,810 Reputación
62 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 7,002
