Saltar al contenido principal
Sony Xperia Z3 Dual Battery Replacement
Qué necesitas
Resumen del Video
  1. Sony Xperia Z3 Dual Battery Replacement, Battery: paso 1, imagen 1 de 2 Sony Xperia Z3 Dual Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Heat the back cover to soften the adhesive sticker.
    • Use the suction cup to open a gap from top side or bottom side.
  2. Sony Xperia Z3 Dual Battery Replacement: paso 2, imagen 1 de 3 Sony Xperia Z3 Dual Battery Replacement: paso 2, imagen 2 de 3 Sony Xperia Z3 Dual Battery Replacement: paso 2, imagen 3 de 3
    • Insert into the guitar pick and slide to cut the sticker.
    • Remove the back cover.
  3. Sony Xperia Z3 Dual Battery Replacement: paso 3, imagen 1 de 1
    • Release battery flex connector carefully to avoid breaking the pins.
  4. Sony Xperia Z3 Dual Battery Replacement: paso 4, imagen 1 de 1
    • Get free that sticker which for fastening the battery.
  5. Sony Xperia Z3 Dual Battery Replacement: paso 5, imagen 1 de 1
    • Pry up with a little effort because there is adhesive under the battery though not so strong.
  6. Sony Xperia Z3 Dual Battery Replacement: paso 6, imagen 1 de 1
    • That's Sony Xperia Z3 Dual 3100mAh battery.
    • When you finished to replace battery and ready to assemble the phone, you need a piece of new back cover adhesive sticker because it's disposable and the old one can't use any more.
Conclusión
12 personas más completaron esta guía.
Sophia
Miembro Desde 03/25/14
43,810 Reputación
62 Guías creadas
2 comentarios
Do you happen to know if the Z3 battery will also fit the Z3v i cant seem to find a replacement specifically for the Z3v
Victor Aguirre - Contestar
Just finished this guide thank you!
Seb Carroll - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 28,211
