Saltar al contenido principal
Introducción
Replace your Sony Xperia Z3 Compact's midframe.
This involves removing the back panel and front screen, separating the main flex, reattaching it, and then reassembling.
  1. First, heat up. And then place the suction cup and pull to open a gap. Insert into the guitar pick to cut the adhesive sticker under the back cover. Finally, remove the back cover.
    • First, heat up.
    • And then place the suction cup and pull to open a gap. Insert into the guitar pick to cut the adhesive sticker under the back cover.
    • Finally, remove the back cover.
  2. Disconnect the NFC flex press connector. Unscrew the screws holding the black midframe in place. Remove back frame.
    • Disconnect the NFC flex press connector.
    • Unscrew the screws holding the black midframe in place.
    • Remove back frame.
  3. Disconnect the battery flex cable.
    • Disconnect the battery flex cable.
  4. Baterías para ordenadores portátiles
    Un pequeño arreglo para un gran resultado.
    Comprar Ahora
    Comprar Ahora
  5. Remove rear camera bracket. Release connector, but take care not to damage the electronic components next to the connector. It is best to access the connector from the bottom (battery side), and not from the side as the picture shows. Remove rear camera.
    • Remove rear camera bracket.
    • Release connector, but take care not to damage the electronic components next to the connector. It is best to access the connector from the bottom (battery side), and not from the side as the picture shows.
    • Remove rear camera.
  6. Release connectors and twist off screw. Release connectors and twist off screw. Release connectors and twist off screw.
    • Release connectors and twist off screw.
  7. Remove motherboard. Lift the red cover off the vibrating motor, and lift the motor with tweezers. The motor should stay attached to the cabling to the motherboard. Lift the red cover off the vibrating motor, and lift the motor with tweezers. The motor should stay attached to the cabling to the motherboard.
    • Remove motherboard.
    • Lift the red cover off the vibrating motor, and lift the motor with tweezers. The motor should stay attached to the cabling to the motherboard.
  8. Remove headphone jack. Use caution lifting the flex cables that are stuck to the midplate. Use caution lifting the flex cables that are stuck to the midplate.
    • Remove headphone jack.
    • Use caution lifting the flex cables that are stuck to the midplate.
  9. Remove loudspeaker. Remove loudspeaker.
    • Remove loudspeaker.
  10. Separate the LCD screen with earpiece from midframe. See the detail on Sony Xperia Z3 Compact LCD screen replacement guide. Finally, you you can reassemble the phone with new midframe. Separate the LCD screen with earpiece from midframe. See the detail on Sony Xperia Z3 Compact LCD screen replacement guide. Finally, you you can reassemble the phone with new midframe. Separate the LCD screen with earpiece from midframe. See the detail on Sony Xperia Z3 Compact LCD screen replacement guide. Finally, you you can reassemble the phone with new midframe.
Conclusión
8 personas más completaron esta guía.
Sophia
Miembro Desde 25/03/14
42,074 Reputación
62 Guías creadas
i want to ask what is the purpose of that plastic frame that have some silver paths connecting to the main board, because i accidentally broke it and broke the one path
coleonyx1 - Contestar
It is WIFI Antenna connectors
gak.vasilis.far -
I have same issue too did you fix it?
gak.vasilis.far -
This is potentially much more complicated, and fiddly, than the guide suggests - depending on where you get the midframe from, there are a number of additional parts that need moving across to the new one - specifically the rubber seals from the buttons, the small microphone channel near the bottom mic, the plastic defuser for the LED next to the headphone socket and the front camera holder. Removing the lower speaker from the midframe is likely to break it, simply down to the glue being used to hold it in. It's worth making sure you have a replacement to hand as they're fairly cheap.
Additionally to re-emphasise, be very careful with removing the mother board, the vibration motor lead is very delicate and easy to tear. Do make sure it's completely freed up before trying to remove the board!
Daniel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 12
Últimos 30 Días: 81
Todo El Tiempo: 15,626
