Saltar al contenido principal
Sony Xperia Z2 Logic Board Replacement
Qué necesitas
Resumen del Video
  1. Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: paso 1, imagen 1 de 3 Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: paso 1, imagen 2 de 3 Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: paso 1, imagen 3 de 3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Logic Board Replacement: paso 2, imagen 1 de 3 Sony Xperia Z2 Logic Board Replacement: paso 2, imagen 2 de 3 Sony Xperia Z2 Logic Board Replacement: paso 2, imagen 3 de 3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Logic Board Replacement: paso 3, imagen 1 de 2 Sony Xperia Z2 Logic Board Replacement: paso 3, imagen 2 de 2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Sony Xperia Z2 Logic Board Replacement, Battery: paso 4, imagen 1 de 3 Sony Xperia Z2 Logic Board Replacement, Battery: paso 4, imagen 2 de 3 Sony Xperia Z2 Logic Board Replacement, Battery: paso 4, imagen 3 de 3
  5. Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: paso 5, imagen 1 de 3 Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: paso 5, imagen 2 de 3 Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: paso 5, imagen 3 de 3
    • Unscrew the screw and remove the Wi-Fi Antenna.
  6. Sony Xperia Z2 Logic Board Replacement, Logic Board: paso 6, imagen 1 de 2 Sony Xperia Z2 Logic Board Replacement, Logic Board: paso 6, imagen 2 de 2
    • Disconnect one by one:
    • Magnetic Charging Dock Flex Cable
    • Volume / Power Button and Microphone Flex Cable
    • Main Camera
    • Audio Jack and Light Sensor Flex cable
    • Coaxial Antenna Cable
  7. Sony Xperia Z2 Logic Board Replacement: paso 7, imagen 1 de 3 Sony Xperia Z2 Logic Board Replacement: paso 7, imagen 2 de 3 Sony Xperia Z2 Logic Board Replacement: paso 7, imagen 3 de 3
Conclusión
19 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,882 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,516 Guías creadas
3 comentarios
Hi
Do anyone knows where I can buy a logic board for Xperia Z2?
Johannes Stockinger - Contestar
https://www.ebay.com/sch/i.html?_from=R4...
or I bought there
https://ru.aliexpress.com/wholesale?catI...
be careful to find cheaper price and for your model D6503 or D6563…
Alexander -
Are you sure Phillips #00 is the correct size of screwdriver? I had difficulty getting one of the screws to turn (the screwdriver kept slipping), so I tried the other sizes in my iOpener Kit and found that the PH#000 seemed to fit them better, and that screw came straight out with it.
Edward Millen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 18,562
