Introducción
A cracked or faulty screen could lead to glass shards or a useless device. In this guide, you will learn how to replace your Sony Xperia Z1 screen so that you may get the absolute best performance out of your device.
Qué necesitas
With caution to hot temperatures, glide a heat gun over the outer edges of the phone bezel to soften the adhesive securing the back panel to the phone.
Remove the bracket on the left side of the motherboard with a pair of tweezers.
Now turn the phone back over to begin removing the screen. Using a heat gun, if possible, heat all edges of the screen in order to loosen the adhesive.
Next, use an opening pick to begin prying the screen from the device. Make sure to be careful, as it is common for the screen to shatter when removing it. Once removed, note where it is connected.
Turn your attention back to the inside of the device, where there is one group of cables connected to the display on the front of the phone. Maneuver these cables, as shown, through the hole so that the screen and cables can be removed from the device. The screen and attached cables will now detach from the phone.
To reassemble your device, follow these instructions in reverse order. Note: don’t forget to reinstall new adhesive strips to the front and back cover, only after removing all of the old adhesive.
Una persona más ha completado esta guía.
