Saltar al contenido principal
Sony Xperia Z1 Compact Screen Replacement
Qué necesitas
  1. Sony Xperia Z1 Compact Screen Replacement, Apply heat: paso 1, imagen 1 de 1
    • Apply heat to the edges.
  2. Sony Xperia Z1 Compact Screen Replacement, Start prying: paso 2, imagen 1 de 1
    • When the glue is warm slowly start prying from the top corner.
  3. Sony Xperia Z1 Compact Screen Replacement, Add more heat if necessary: paso 3, imagen 1 de 1
    • If the glue is cooled down heat more. Don't force it.
  4. Sony Xperia Z1 Compact Screen Replacement, Cable: paso 4, imagen 1 de 1
    • Remove the data cable from the phones body.
  5. Sony Xperia Z1 Compact Screen Replacement, Testing new screen: paso 5, imagen 1 de 1
    • Test if the new screen works properly.
  6. Sony Xperia Z1 Compact Screen Replacement, The tape: paso 6, imagen 1 de 1
    • If the screen works, remove the new screen and add the double sided tape
  7. Sony Xperia Z1 Compact Screen Replacement, Connecting new screen: paso 7, imagen 1 de 1
    • Connect the new screen to the phone.
  8. Sony Xperia Z1 Compact Screen Replacement, Apply force: paso 8, imagen 1 de 1
    • Now push town not to tight not to softly to the screen.
    • And that's it. You finished the screen replacement.
Conclusión
30 personas más completaron esta guía.
jaanparker
Miembro Desde 01/21/16
952 Reputación
1 Guía escrita
5 comentarios
There is a very good Youtube video of this. I think these are screenshots from it.
Andrew - Contestar
Good video! Help me too! Thanks
Clodoaldo Castro - Contestar
There is a thin, soft foam layer on the backside of the factory screen assembly, right behind the LCD backlight. This insulation foam is missing from most replacement screens. It can be peeled off relatively easily, but it will not stick easily onto the replacement LCD. I am not sure whether it is required at all, does anybody have experience and recommendations concerning this?
sinistre - Contestar
My lcd burn before use Heat gun! Very sad!
Use t7000 glue for glueing screen back down,sure way of it not lifting off
Marcus Roach - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 25
Todo El Tiempo: 17,719
