Introducción
This guide will teach you how to replace the motherboard on your Sony Xperia Z1 Compact. If there are issues turning your phone on, follow the troubleshooting guide and if nothing else listed above this helps, then it may solve the problem.
Qué necesitas
Heat along the edges of the back cover using a heat gun to soften the glue.
Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
Remove the square rubber gasket from the camera using the plastic spudger.
2 personas más completaron esta guía.
Un comentario
hi
Recently i brought Xperia Z1 now i am facing charging problem.
i already change new to battery but it is charging 75 % only.
after charging 75% my phone screen continually on and off
please let me know how can i fix this problem.
