Introducción
This guide will show you how you replace the headphone jack.
Qué necesitas
Heat along the edges of the back cover using a heat gun to soften the glue.
Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
Remove the square rubber gasket from the camera using the plastic spudger.
To remove the headphone jack, cut the sticker between the headphone jack and the midframe with sharp tweasers.
