Saltar al contenido principal
Sony Xperia Z1 Compact Battery Replacement
Qué necesitas
  1. Sony Xperia Z1 Compact Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Heat along the edges of the back cover using a heat gun to soften the glue.
  2. Sony Xperia Z1 Compact Battery Replacement: paso 2, imagen 1 de 1
    • Attach the small suction cup to the back cover near the bottom of the phone.
    • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
  3. Sony Xperia Z1 Compact Battery Replacement: paso 3, imagen 1 de 2 Sony Xperia Z1 Compact Battery Replacement: paso 3, imagen 2 de 2
    • Move the spudger around the edge of the back cover to separate it from the black adhesive.
    • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
  4. Sony Xperia Z1 Compact Battery Replacement, Battery: paso 4, imagen 1 de 2 Sony Xperia Z1 Compact Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
  5. Sony Xperia Z1 Compact Battery Replacement: paso 5, imagen 1 de 2 Sony Xperia Z1 Compact Battery Replacement: paso 5, imagen 2 de 2
    • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
  6. Sony Xperia Z1 Compact Battery Replacement: paso 6, imagen 1 de 1
    • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
  7. Sony Xperia Z1 Compact Battery Replacement: paso 7, imagen 1 de 1
    • Remove the battery from the device
Conclusión
12 personas más completaron esta guía.
kinan badr
Miembro Desde 09/21/17
386 Reputación
1 Guía escrita
3 comentarios
is there any reliable source for good replacement battery purchase?
Upendra Gandhi - Contestar
What is the Ariel stuck on the battery ?
Tony - Contestar
NFC Antenna. You should carefully transplant it to new battery, in case your new battery is without one (what is the case for most 3rd party batteries available)
Peter Pepo -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 28
Todo El Tiempo: 11,467
