Saltar al contenido principal
Sony Xperia Z1 Compact Back Cover Replacement
Qué necesitas
  1. Sony Xperia Z1 Compact Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Heat along the edges of the back cover using a heat gun to soften the glue.
  2. Sony Xperia Z1 Compact Back Cover Replacement: paso 2, imagen 1 de 1
    • Attach the small suction cup to the back cover near the bottom of the phone.
    • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
  3. Sony Xperia Z1 Compact Back Cover Replacement: paso 3, imagen 1 de 2 Sony Xperia Z1 Compact Back Cover Replacement: paso 3, imagen 2 de 2
    • Move the spudger around the edge of the back cover to separate it from the black adhesive.
    • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 22
Todo El Tiempo: 2,172
