Saltar al contenido principal
Sony Xperia XZ2 Front Camera Replacement
Qué necesitas
  1. Sony Xperia XZ2 Front Camera Replacement, LCD Screen: paso 1, imagen 1 de 3 Sony Xperia XZ2 Front Camera Replacement, LCD Screen: paso 1, imagen 2 de 3 Sony Xperia XZ2 Front Camera Replacement, LCD Screen: paso 1, imagen 3 de 3
    • Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
    • The phone gets very hot and can hurt the user handling it.
  2. Sony Xperia XZ2 Front Camera Replacement: paso 2, imagen 1 de 3 Sony Xperia XZ2 Front Camera Replacement: paso 2, imagen 2 de 3 Sony Xperia XZ2 Front Camera Replacement: paso 2, imagen 3 de 3
    • Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
    • If the glue hardens and becomes difficult to move the plastic around the edges, reheat the phone.
  3. Sony Xperia XZ2 Front Camera Replacement: paso 3, imagen 1 de 2 Sony Xperia XZ2 Front Camera Replacement: paso 3, imagen 2 de 2
    • Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
    • The screen is still attached by a connector, so do not pull the pieces apart.
  4. Sony Xperia XZ2 Front Camera Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    $3.99
    • Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
  5. Sony Xperia XZ2 Front Camera Replacement: paso 5, imagen 1 de 1
    • Gently remove the connector by using a spudger to pop it off.
  6. Sony Xperia XZ2 Front Camera Replacement, Front Camera: paso 6, imagen 1 de 1
    • Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
    • Remove the one 3 mm Phillips #00 screws.
    • Remove the two 1mm Phillips #00 screws.
    • Fifteen screws should be removed in total in this step. (Not all the screws are visible in the picture.)
  7. Sony Xperia XZ2 Front Camera Replacement: paso 7, imagen 1 de 1
    • Lift the metal screen shield out of the phone.
  8. Sony Xperia XZ2 Front Camera Replacement: paso 8, imagen 1 de 3 Sony Xperia XZ2 Front Camera Replacement: paso 8, imagen 2 de 3 Sony Xperia XZ2 Front Camera Replacement: paso 8, imagen 3 de 3
    • Use the spudger to pop off the plastic protector.
  9. Sony Xperia XZ2 Front Camera Replacement: paso 9, imagen 1 de 1
    • Gently pry up the battery flex connector using the spudger.
Conclusión
Chloe
Miembro Desde 01/24/19
217 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S19-G5, White Winter 2019 Miembro de Cal Poly, Team S19-G5, White Winter 2019
CPSU-WHITE-W19S19G5
Miembros de 4
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 1,097
