Saltar al contenido principal
Sony Xperia XA2 Ultra Headphone Jack Replacement
Qué necesitas
  1. Sony Xperia XA2 Ultra Headphone Jack Replacement, Rear Cover: paso 1, imagen 1 de 2 Sony Xperia XA2 Ultra Headphone Jack Replacement, Rear Cover: paso 1, imagen 2 de 2
    • Turn off your phone before continuing.
    • Remove the SIM card tray on the left side of the phone using a SIM card eject tool.
  2. Sony Xperia XA2 Ultra Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Heat the edge of the phone with the heat gun (recommended) for 30 seconds.
    • If you don't have a heat gun, a hair dryer can be used.
    • Use the hair dryer on the highest setting, constantly going around the phone to heat all of the edges.
    • The phone will become hot to the touch. Use gloves or a towel to touch the phone.
  3. Sony Xperia XA2 Ultra Headphone Jack Replacement: paso 3, imagen 1 de 2 Sony Xperia XA2 Ultra Headphone Jack Replacement: paso 3, imagen 2 de 2
    • Apply the suction handle near an edge of the phone and pull upwards while trying to get an opening large enough for an iFixit opening pick.
  4. Sony Xperia XA2 Ultra Headphone Jack Replacement: paso 4, imagen 1 de 2 Sony Xperia XA2 Ultra Headphone Jack Replacement: paso 4, imagen 2 de 2
    • Pry upwards with the pick to start pulling the rear cover off the adhesive it’s attached to.
    • Insert a second pick once there is enough room.
  5. Sony Xperia XA2 Ultra Headphone Jack Replacement: paso 5, imagen 1 de 2 Sony Xperia XA2 Ultra Headphone Jack Replacement: paso 5, imagen 2 de 2
    • Take one of the picks and try to slide it down the side of the phone, pulling more of the cover off the adhesive.
    • The iFixit opening tool may also be used to gain better leverage.
    • The rear cover will pop off.
  6. Sony Xperia XA2 Ultra Headphone Jack Replacement: paso 6, imagen 1 de 1
    • Once the rear cover is off, use the iFixit opening tool to detach the flex cable.
  7. Sony Xperia XA2 Ultra Headphone Jack Replacement, Motherboard Bracket: paso 7, imagen 1 de 2 Sony Xperia XA2 Ultra Headphone Jack Replacement, Motherboard Bracket: paso 7, imagen 2 de 2
    • Remove the six 3 mm Phillips #000 screws.
  8. Sony Xperia XA2 Ultra Headphone Jack Replacement: paso 8, imagen 1 de 1
    • Remove the motherboard bracket with an iFixit opening tool.
  9. Sony Xperia XA2 Ultra Headphone Jack Replacement, Headphone Jack: paso 9, imagen 1 de 1
    • Remove the single 3 mm screw using a Phillips #000 screwdriver.
  10. Sony Xperia XA2 Ultra Headphone Jack Replacement: paso 10, imagen 1 de 1
    • Use the Jimmy to pry and remove the headphone jack.
Conclusión
Alyssa Bayles
Miembro Desde 09/27/22
819 Reputación
8 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 94
