Introducción
This guide will show you how to remove the antenna module from your Sony Xperia XA1 Ultra. The antenna module will need to be removed to access other parts of the phone or replaced if the phone experiences connectivity issues. A heat gun or hairdryer is needed to open the back panel, which can become hot and potentially damage the phone. In addition, a T5 screwdriver is needed to remove screws and a spudger is used to lift up components of the phone.
Qué necesitas
Wedge your finger under the bottom ridge of the SD card insert.
Pull outwards with your fingers to remove the SD card from the left side of device.
Herramienta utilizada en este paso:Plastic Cards$2.99
Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
Remove the four 4mm T5 screws on the top of the black panel securing the antenna module to the device.
Una persona más ha completado esta guía.
