Saltar al contenido principal
Sony Xperia XA Back Camera Replacement
Qué necesitas
  1. Sony Xperia XA Back Camera Replacement, Back Cover: paso 1, imagen 1 de 1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Back Camera Replacement: paso 2, imagen 1 de 1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Back Camera Replacement: paso 3, imagen 1 de 3 Sony Xperia XA Back Camera Replacement: paso 3, imagen 2 de 3 Sony Xperia XA Back Camera Replacement: paso 3, imagen 3 de 3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Back Camera Replacement: paso 4, imagen 1 de 3 Sony Xperia XA Back Camera Replacement: paso 4, imagen 2 de 3 Sony Xperia XA Back Camera Replacement: paso 4, imagen 3 de 3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Back Camera Replacement: paso 5, imagen 1 de 1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Back Camera Replacement: paso 6, imagen 1 de 1
    • Peel back the RAF antenna.
  7. Sony Xperia XA Back Camera Replacement, Motherboard: paso 7, imagen 1 de 2 Sony Xperia XA Back Camera Replacement, Motherboard: paso 7, imagen 2 de 2
    • Pry up the copper connector next to the battery with the plastic opening tool.
  8. Sony Xperia XA Back Camera Replacement: paso 8, imagen 1 de 2 Sony Xperia XA Back Camera Replacement: paso 8, imagen 2 de 2
    • Remove the five black 4mm screws with a Phillips #00 Screwdriver.
  9. Sony Xperia XA Back Camera Replacement: paso 9, imagen 1 de 3 Sony Xperia XA Back Camera Replacement: paso 9, imagen 2 de 3 Sony Xperia XA Back Camera Replacement: paso 9, imagen 3 de 3
    • Pry up the black camera case with the plastic opening tool and then remove the case.
  10. Sony Xperia XA Back Camera Replacement: paso 10, imagen 1 de 2 Sony Xperia XA Back Camera Replacement: paso 10, imagen 2 de 2
    • Pop off the small connector on the right side of the motherboard with the plastic opening tool.
  11. Sony Xperia XA Back Camera Replacement: paso 11, imagen 1 de 2 Sony Xperia XA Back Camera Replacement: paso 11, imagen 2 de 2
    • Use the spudger to take off the connector in the top right of the motherboard.
  12. Sony Xperia XA Back Camera Replacement: paso 12, imagen 1 de 3 Sony Xperia XA Back Camera Replacement: paso 12, imagen 2 de 3 Sony Xperia XA Back Camera Replacement: paso 12, imagen 3 de 3
    • Use the flat end of the spudger to peel up the copper tab to the right of the back camera.
    • Peel back the tab past the connector.
    • Tab is stuck with adhesive.
  13. Sony Xperia XA Back Camera Replacement: paso 13, imagen 1 de 3 Sony Xperia XA Back Camera Replacement: paso 13, imagen 2 de 3 Sony Xperia XA Back Camera Replacement: paso 13, imagen 3 de 3
    • Pry up the camera's connector to the motherboard with the nylon spudger.
  14. Sony Xperia XA Back Camera Replacement: paso 14, imagen 1 de 2 Sony Xperia XA Back Camera Replacement: paso 14, imagen 2 de 2
    • Use the spudger to loosen the black connector from the top right of the motherboard.
  15. Sony Xperia XA Back Camera Replacement: paso 15, imagen 1 de 3 Sony Xperia XA Back Camera Replacement: paso 15, imagen 2 de 3 Sony Xperia XA Back Camera Replacement: paso 15, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Pull out the square shaped connector using tweezers.
  16. Sony Xperia XA Back Camera Replacement: paso 16, imagen 1 de 2 Sony Xperia XA Back Camera Replacement: paso 16, imagen 2 de 2
    • Use the spudger to detach the three copper connectors on the bottom area of the motherboard.
  17. Sony Xperia XA Back Camera Replacement: paso 17, imagen 1 de 3 Sony Xperia XA Back Camera Replacement: paso 17, imagen 2 de 3 Sony Xperia XA Back Camera Replacement: paso 17, imagen 3 de 3
    • Use the spudger to separate the motherboard from the frame.
    • Pull out the motherboard using your fingers.
  18. Sony Xperia XA Back Camera Replacement, Back Camera: paso 18, imagen 1 de 2 Sony Xperia XA Back Camera Replacement, Back Camera: paso 18, imagen 2 de 2
    • Use the nylon spudger to pry up the black camera connector from the motherboard.
    • The connector is attached with adhesive.
  19. Sony Xperia XA Back Camera Replacement: paso 19, imagen 1 de 1
    • Use your fingers to gently pull the camera off the motherboard.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S17-G2, Livingston Spring 2018 Miembro de Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 841
