Saltar al contenido principal
Sony Xperia U Speaker Replacement
Qué necesitas
  1. Sony Xperia U Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Speaker Replacement: paso 2, imagen 1 de 1
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. Sony Xperia U Speaker Replacement, Headphone Jack: paso 3, imagen 1 de 1
    • Insert the plastic opening tool in between the white plastic cover, and the body of the phone.
    • Pop the plastic cover off. To do this, gently push forward on the plastic opening tool while it is in between the cover and the phone.
  4. Sony Xperia U Speaker Replacement: paso 4, imagen 1 de 1
    • Remove the six size 0 Phillips screws.
  5. Sony Xperia U Speaker Replacement: paso 5, imagen 1 de 1
    • Insert the plastic opening tool in between the body of the phone and the thin plastic back cover.
    • Lift the black back cover off of the body with the plastic tool.
  6. Sony Xperia U Speaker Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Locate the earphone jack on the top left of the black plastic back cover.
    • Use the tweezers to pinch the earphone jack and remove it from the back cover.
  7. Sony Xperia U Speaker Replacement, Speaker: paso 7, imagen 1 de 1
    • Using the tweezers, remove the loudspeaker module by firmly grasping it on one side, then slowly and carefully pulling the module in an upward direction.
Conclusión
3 personas más completaron esta guía.
Bader
Miembro Desde 10/07/14
545 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 7-2, Leahy Fall 2014 Miembro de USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
Miembros de 4
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 14
Todo El Tiempo: 953
