Saltar al contenido principal
Sony Xperia TL Motherboard Replacement
Qué necesitas
  1. Sony Xperia TL Motherboard Replacement, Remove Top Plastic Section: paso 1, imagen 1 de 3 Sony Xperia TL Motherboard Replacement, Remove Top Plastic Section: paso 1, imagen 2 de 3 Sony Xperia TL Motherboard Replacement, Remove Top Plastic Section: paso 1, imagen 3 de 3
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Motherboard Replacement, Remove Bottom Plastic Section: paso 2, imagen 1 de 2 Sony Xperia TL Motherboard Replacement, Remove Bottom Plastic Section: paso 2, imagen 2 de 2
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Motherboard Replacement, Unscrewing the Back Off: paso 3, imagen 1 de 3 Sony Xperia TL Motherboard Replacement, Unscrewing the Back Off: paso 3, imagen 2 de 3 Sony Xperia TL Motherboard Replacement, Unscrewing the Back Off: paso 3, imagen 3 de 3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Motherboard Replacement, Battery: paso 4, imagen 1 de 3 Sony Xperia TL Motherboard Replacement, Battery: paso 4, imagen 2 de 3 Sony Xperia TL Motherboard Replacement, Battery: paso 4, imagen 3 de 3
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
  5. Sony Xperia TL Motherboard Replacement, Sony Xperia TL Auxiliary Cord Replacement: paso 5, imagen 1 de 2 Sony Xperia TL Motherboard Replacement, Sony Xperia TL Auxiliary Cord Replacement: paso 5, imagen 2 de 2
    • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
  6. Sony Xperia TL Motherboard Replacement, Motherboard: paso 6, imagen 1 de 3 Sony Xperia TL Motherboard Replacement, Motherboard: paso 6, imagen 2 de 3 Sony Xperia TL Motherboard Replacement, Motherboard: paso 6, imagen 3 de 3
    • Use the Phillips #00 to remove the 3 5mm screws.
    • Lift the plastic cover off.
    • Use the plastic opening tool to pry the motherboard out of the phone shell.
Conclusión
Una persona más ha completado esta guía.
Adam Giniger
Miembro Desde 09/22/14
1,303 Reputación
8 Guías creadas
Equipo
USF Tampa, Team 4-4, Brown Fall 2014 Miembro de USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 539
