Saltar al contenido principal
Sony Xperia TL Headphone Jack Replacement
Qué necesitas
  1. Sony Xperia TL Headphone Jack Replacement, Remove Top Plastic Section: paso 1, imagen 1 de 3 Sony Xperia TL Headphone Jack Replacement, Remove Top Plastic Section: paso 1, imagen 2 de 3 Sony Xperia TL Headphone Jack Replacement, Remove Top Plastic Section: paso 1, imagen 3 de 3
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Headphone Jack Replacement, Remove Bottom Plastic Section: paso 2, imagen 1 de 2 Sony Xperia TL Headphone Jack Replacement, Remove Bottom Plastic Section: paso 2, imagen 2 de 2
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Headphone Jack Replacement, Unscrewing the Back Off: paso 3, imagen 1 de 3 Sony Xperia TL Headphone Jack Replacement, Unscrewing the Back Off: paso 3, imagen 2 de 3 Sony Xperia TL Headphone Jack Replacement, Unscrewing the Back Off: paso 3, imagen 3 de 3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Headphone Jack Replacement, Battery: paso 4, imagen 1 de 3 Sony Xperia TL Headphone Jack Replacement, Battery: paso 4, imagen 2 de 3 Sony Xperia TL Headphone Jack Replacement, Battery: paso 4, imagen 3 de 3
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
  5. Sony Xperia TL Headphone Jack Replacement, Sony Xperia TL Auxiliary Cord Replacement: paso 5, imagen 1 de 2 Sony Xperia TL Headphone Jack Replacement, Sony Xperia TL Auxiliary Cord Replacement: paso 5, imagen 2 de 2
    • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
  6. Sony Xperia TL Headphone Jack Replacement, Motherboard: paso 6, imagen 1 de 3 Sony Xperia TL Headphone Jack Replacement, Motherboard: paso 6, imagen 2 de 3 Sony Xperia TL Headphone Jack Replacement, Motherboard: paso 6, imagen 3 de 3
    • Use the Phillips #00 to remove the 3 5mm screws.
    • Lift the plastic cover off.
    • Use the plastic opening tool to pry the motherboard out of the phone shell.
  7. Sony Xperia TL Headphone Jack Replacement, Headphone Jack: paso 7, imagen 1 de 1
    • Use the plastic opening tool to detach the headphone jack from the motherboard.
    • Remove the motherboard and slide the headphone jack out of its slot.
Conclusión
Una persona más ha completado esta guía.
Nathan Laneau
Miembro Desde 09/22/14
435 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 4-4, Brown Fall 2014 Miembro de USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
Miembros de 3
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 263
