Saltar al contenido principal
Sony Xperia TL Battery Harness Replacement
Qué necesitas
  1. Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: paso 1, imagen 1 de 3 Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: paso 1, imagen 2 de 3 Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: paso 1, imagen 3 de 3
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Battery Harness Replacement, Remove Bottom Plastic Section: paso 2, imagen 1 de 2 Sony Xperia TL Battery Harness Replacement, Remove Bottom Plastic Section: paso 2, imagen 2 de 2
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: paso 3, imagen 1 de 3 Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: paso 3, imagen 2 de 3 Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: paso 3, imagen 3 de 3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Battery Harness Replacement, Loud Speaker: paso 4, imagen 1 de 3 Sony Xperia TL Battery Harness Replacement, Loud Speaker: paso 4, imagen 2 de 3 Sony Xperia TL Battery Harness Replacement, Loud Speaker: paso 4, imagen 3 de 3
    • Use the plastic opening tool to remove the loud speaker module.
  5. Sony Xperia TL Battery Harness Replacement, Sony Xperia TL Auxiliary Cord Replacement: paso 5, imagen 1 de 2 Sony Xperia TL Battery Harness Replacement, Sony Xperia TL Auxiliary Cord Replacement: paso 5, imagen 2 de 2
    • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
  6. Sony Xperia TL Battery Harness Replacement, Battery Harness: paso 6, imagen 1 de 3 Sony Xperia TL Battery Harness Replacement, Battery Harness: paso 6, imagen 2 de 3 Sony Xperia TL Battery Harness Replacement, Battery Harness: paso 6, imagen 3 de 3
    • Unhook the 2 connections between the harness and phone shell.
    • Using the plastic opening tool, pry the harness up and remove it.
    • There is an adhesive on the bottom half of the battery harness.
  7. Sony Xperia TL Battery Harness Replacement: paso 7, imagen 1 de 1
    • The final step is taking the entire harness off of the phone.
Conclusión
Una persona más ha completado esta guía.
Adam Giniger
Miembro Desde 09/22/14
1,303 Reputación
8 Guías creadas
Equipo
USF Tampa, Team 4-4, Brown Fall 2014 Miembro de USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
Miembros de 3
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 360
